New 836 with Ti head, New CR29 w/ stacks, Light weight flywheel FS
firstcycles
I have a new never been installed/fired 836 motor with Titanium valves, springs, and retainers. I picked it up as part of a package deal and as much as it pains me not to use it, I need to free up some cash. Asking $3500
I also picked up a set of CR29s with velocity stacks, new in the box, never installed. They were purchased for the 836. If the purchaser needs to know I'll open them up and get the jet sizes. Asking $700
I also have a light weight racing flywheel, I dont know any more about it, or what its worth. Based on what stock ones are going for I'm going to ask $250
All prices are plus shipping, I will ship the engine if the buyer wants to pay for it to be created and shipped, but I would prefer to handel the engine transaction in person. I'm new to the forum but I'm fairly active on the cb1100f.net forum under the screen name "kenc42" if you want to check references.
I didn't take these pics to advertise the stuff for sale so I'll be adding more/better pics tomorrow.
https://www.dropbox.com/sh/zrpgd69u7014yck/20SMCMzh_s
pretty sure titanium valves will turn to firecrackers in an air cooled motor... you sure they're not just titanium retainers?
Fwiw I have titanium valves in my XS650 (750). Sourced from a NASCAR engine and machined to fit with the matching ti retainers etc.
Havent blown up yet and had it up to 9000 rpm. They have steel ends on them where the tappets hit I believe. Otherwise you can run the little steel hats on them. Also good for closing up lash if you have short valves.
OK I talked to the PO, he said the engine was built by Ray's Honda near Thomasville, NC. It has Ti springs and retainers and Manley valves. He doesnt remember the name of the pistons but hes going to see what he can find on them. All parts to build the engine were NOS.
Unless that comes with a transferrable warranty you are absolutely out of your gourd :)
Well I'd start with what it would take to replicate it, and then cut a big chunk off that. There is a lot of value in 'knowing' what has been done to an engine and in having either done it yourself or making the choices of who to trust with it.
The valves and springs are worth a few hundred dollars on their own, depending on different things like where they came from, who made them etc.
Not knowing what, if anything, has been done to the valve guides, if the head has been ported (properly), if the cam has a performance grind, if the valves are stock or standard size etc. makes it impossible to figure it out.
Also not knowing what piston kit was used, whether the rods were swapped out, crank balanced.... also makes it impossible to confirm.
You'd also want to identify what year/model the engine came from. Some of the CB750 engines (CB750F as I recall) had problematic heads for some reason I don't remember.
Bottom line:
$300 Engine (just ballparking a used engine in unknown condition for a rebuild)
$500 Wiseco 836 kit (you can buy RC Engineering for $250)
$600 Titanium valves (8 valves / springs / retainers at $75 each - shot in the dark)
$300 Valve job - grinding seats etc.
$200 Gaskets / seals
$400 Bore/hone of 4 cylinders - overpricing as it's potentially a lot of material to remove
$800 10 hours labor to tear it down and put it back together
$3100
Keeping in mind $800 of that is labor at $80 per hour that most of us wouldn't spend. Again, those are just WAG ballpark pricing.
Now, if the head was ported properly by someone who knows what they're doing, that adds a chunk to the value. With titanium valves, I'd hope there is a hot cam and a ported head to feed the big bore cylinders. Would be kind of silly to not do the head work.
BTW - I don't usually chime in on the for sale threads - like to stay neutral and let the market take care of itself. But, there seemed to be an invitation to comment on the pricing, and I've just gone through 2 performance engine builds. Plus the only posts you have here are to sell things - so I figured it's fair game :)
