New basketcas
axeugene27
Over 1,000 Posts
I am pretty new here bought a basket case cb350 want to attempt to start the thing before i sink my life savings into beautifying it. What do you suppose bare minimum i need on the bike to attempt a to get it to run.? The engine is in the frame but all the electrical and fuel stuff is stripped. i am thinking battery, coils, carbs, gas. I am a little concerned about electrical pretty new at wrenching aside from cosmetic surgery. any suggestions>
Photos are worth a thousand words. Show us what you are dealing with.
I am here: http://tapatalk.com/map.php?jv4ch1
I got 2 rolling frames 1 "working" engine 2 parts engines, 2 tanks, box o random stuff. One frame is even titled! I paid 400 bucks. So far all i've done is stripped and sanded, clear coated the tank. I got a battery on it, coils on it, overrided the kill switch. left cylinder has 150 compression, right cylinder 160 I put in new plugs, there is spark at the plugs not a huge spark but its there. I put on the ignition switch, i put on the carbs and put some gas in/. It looks like the prev owner cleaned the carbs so i haven't done much to them. I opened them up they look pretty clean. I don't know how to ensure they are all clear though? The starter works but i can't get it to start. It just glugs and glugs. It did backfire slightly a couple times. The throttle isn't on so i cant give it throttle as i crank it. I did open the choke but don't have a filter on it. I am kind of out of ideas. I guess i will try to rebuild the carbs although i am pretty sure they are clean. ANY IDEAS?
Uploaded with ImageShack.us
Uploaded with
Uploaded with ImageShack.usageshack.us]ImageShack.us[/URL]
bump..... I rebuilt the carb, regapped the points, and set the ignition timing. i connected it to my magna battery and cranked away. Still nothing. There is spark,,, i even got shocked once. it is far from a thick blue spark though. I don't know if it is a bad coil or if the carb is just shot or what. How can i be sure the carb is delivering fuel? It doesnt even fire with starting fluid sprayed into the intakes so i am thinking maybe the coils are no good. I am thinking of just saying to hell with it and buying new mikuni carbs with dyna ignition. don't want to if i don't have to though. Any suggestions?
