New brakes for a CB550
Shooter
I want to change the brake system out on my CB550 because I am used to something a lot more" effective".
I am thinking of keeping the front rotor (drilled) and losing the whole system to the calliper. Replacing all that with new Levers, reservoir, braided lines and new sensor for the stop light. This means a new throttle I guess because the original is integrated to the lever.
Any ideas. Cost is not really an issue. I want decent brakes!
The CB550 throttle and master cylinder/lever unit are seperate, aren't they? Seemed to be the case on my CB500K and CB550F. You should be fine with a different master cylinder/lines/pressure sensor/calipers.
That being said if you're going to go through all that, you should adapt some floating rotors to the CB550 hub.
Put dual drilled discs and calipers on the front for a nice upgraded stock type arrangement. Braided lines and a newer sportbike master cylinder are a good start. That would be the cost effective way to do it.
If cost isn't an issue, change the front end completely. GL 1000 forks, dual 6 piston calipers, 900RR discs.
DG
Does changing out the entire front end retain the original front wheel?
@Tintin - yep the throttle and the brake lever are separate but the clutch and grip are not. Could end up with two different levers
True - the left side switch housing also includes the lever mount. That can be solved with a different seperate set of switches from another bike however.
Usually you can keep the Stock front wheel. It depends on the front end you are using. I like to keep Honda front ends on Hondas,etc. The pics posted have the stock CB 750 hub laced to an aluminum rim.
DG
Same front end. different brakes
What do you want to do on your cb550??... An endo??..
I'd just change the Master Cylinder & lever to a late model Busa set up or a 600rr then change the brake lines to a braided stainless steel at first.
See how you like that set up first. Yóu'll see an huge improvement than stock.
Then if you want to be thrown over your bars and land on your back in front of the chics, then go through the hassle of changing your calipers and rotors.
For the easiest swap, just upgrade your forks to a 76/77 cb750f front w. dual disks and just use their front wheel that has bigger rotors than the cb550.
The forks would have to be changed also. The antique swinging caliper arrangement doens't lend itself to these mods.
Sure, you can do an endo with the new brakes, but with the greatly imnproved braking feel, you would have to be trying to do an endo.
The easiest swap would be to just put duals on the existing stock 550 forks.
DG
if you can find a 77-78 supersport front end it will bolt right on!,,,,chuck the comstar mag! lighter 750 dohc (post 79) rotors will fit. go to classic brake.com it will explain why your brakes feel like wood!...a smaller diameter master will greatly improve your brake system(hydraulic ratio's)
DG
What does a guy need to put a set of duals on the existing stock 550 forks? Is it just a matter of a second line teed in and another factory rotor and caliper bolted on?
Yep, you need a different master cyl though as original won't move enough fluid for dual disc.
Early Yamaha work well as they had dual piston caliper, but anything with either dual piston or dual disc single piston works
