Check the resistance of the coils you are replacing to ensure a correct
match.
Never select a coil with a lower resistance than your ignition system
- this will cause the coils to overheat and burn out... It is OK to select coils
with a slightly higher resistance. For example 3.0 ohm coils with a 1.5 ohm CDI
ignition. While this isn't optimal, it works and allows you to switch your CDI
ignition over to a Dyna-S in the future.
mechdesign2k4 said:You can pull the wires out and epoxy new ones in
