I don't have experience of the Pamco but he's been around a while, was originally on XS650 Garage if I remember right?
Anyway, I do have some experience of electronic ignition on CB360's.
It's a major upgrade and worth the cash
Bike starts easier and runs much better as long as if it stays in one piece.
In my opinion, the issue seems to be the CB360 heads run hotter than CB350 or XS650, probably because of unitary construction instead of separate cam carriers with gaskets (may not be much but it does make a difference)
I think Pete has been doing some tweaking to keep it reliable plus, I think he has a settable rev limiter? (been years since I looked at specifications)
Dyna doesn't seem able to last more than a few thousand miles, even with slots cut in the outer cover to help it stay cool (you probably know heat is the major issue with electronics, makes them 'age' real fast then break)
when you start getting over 200f (normal for 360) it's only a matter of time before it breaks.
The Pamco has separate 'blue box' which can be mounted somewhere way cooler,
If the hall effect sensors fail they are relatively easy and cheap(ish) to swap out with new ones but I think they may be upgraded to military/NASA/aircraft spec now? (probably 10~20 times the price but still less than $10.00 each ;D )
