maddog5150
So I fried the wiring harness about a month ago and even when it was fried, the headlight was on (for example)
Well I bought a new wiring harness, converted over to blade fuses and put everything together carefully using a wiring diagram (Kind of hard to screw it up when everything is color cordinated) but NOTHING works save for the lights on the guage. I have no effing clue what I did wrong and I even disconnected everything, went step by step and NOTHING is working at all (except the tach and speedometer lights)
Is there a common step that is missed?
Also, I have this connector on the wiring harness that does not have a home. On the previous wiring harness, this wire was cut and twisted somewhere but I cant find where
I doubt this will fix the solution but if you guys could point me out what its supposed to be attached to, at least it will eliminate a potential problem.
CB750k6
its the green wire
CB750k6
its the green wire
