New From North Carolina
hbluvsmg
I am relatively new to the biking world and new to DTT. I waited until I was 31 to ever ride a motorcycle and now that is all I can think about. I daydream about bikes all day and continue to dream about them when I sleep. I currently own a 1978 GL1000 which is also my first bike.
I just purchased my first project which consists of two bikes that I plan to use to build one bike. The first bike is a 1977 XS750 with a title. The original owner of the bike was in the process of changing the oil when his son took it for a ride unaware that the oil was drained. You can only imagine what that did to the engine. The second is an untitle 19** XS850 barnfind without a title. I plan on pulling the 850 engine and transplanting it into the 750 frame. I have reviewed a lot of posts on this forum and other forums and I believe I am going to make a "frankenbike." A lot of builders have put R6 forks and brakes on the XS750s as well as carbs from three cylinder Triumphs. Everyone seems to have significant performance and handling improvements with the above mentioned modifications. It will be a tremendous learning process for me but I look forward to gaining as much knowledge from the experienced members of DTT to build my dream bike.
Thank you to all of the previous members who have posted so many great threads so far. I am more excited about building my bike with so much knowledge available on DTT.
Welcome!
There are quite a few NC folks on here. Tell us where you are, and chances are there are like minded folks around to BS with in person.
I'm currently working on a 78 GL1000 motor for my nephew, and I have friends building a triple up in OH.
There is a TON of information on here. The search function is your best friend.
Welcome to the madness!
cool idea, lots of the yamaha parts used standard sizing so swapping to new parts is sometimes really easy, for the front end swap, a lot of times you need to slug and reweld the steering stem because the older neck tubes are longer from bearing to bearing. also, there's less offset on newer front ends, because the rake angle is around 24' as opposed to around 27' for older bikes, so you'll probably want to measure the current trail and rework the bike to duplicate that at first
Bozz said:
Welcome!
I am in Huntersville just north of Charlotte. I love BSing, especially about bikes.
Welcome to the site. Make your plans now to join us all in October down in Birmingham AL at the Barber Vintage Festival. Good times, and you're close! Only a 5-6 hour trek.
There is a ton of information throughout the internet regarding swapping stems and bearing converstions, but there is not a lot of information regarding how to properly measure trail and how to adjust for rake angles. I think that you bring up an important topic. After all, the point of the fork conversion is to improve performance versus reducing the handling for the sake of looking cool. Thank you for the heads up. I will definately search the internet and talk to as many people as possible before I commit to a certain fork assembly and design. I want to do as much to my project as I can by myself. However, if I just can't figure it out, I am not above going to a professional. I'd rather spend extra money on suspension and braking if I need to so that I can improve my odds of riding safely.
Thank you again for your reply.
I looked at the website. I will definately be attending Lord willing. Looks like a hell of a good time.
In Charlotte there are several annual events coming up, as well as a loose community of folks based around a core group called the "Queen City Aces".
Coming up at the end of April is "The Meltdown" (in Henderson iirc) and in June (I think) is "Mods s. Rockers Charlotte".
If you are on facebook, that is another good way to connect with like minded folks.
I suggest you try to attend either or both of these if you can. (info can be found here on DTT by using the search function)
If you're up for it, on April 13 those of us in the Raleigh area are putting on a small show called "Raleigh Eurobike".
Welcome!
