New guy with CB360. Running/electrical issues.
Do you have all the wires from your stator connected or have you left one off? I ask because I wired my CL350 from scratch and could not figure out why there was an extra wire coming off the stator. It turns out, that extra wire energizes the system when the headlight is turned on. Once I connected that, my charging system worked fine. Personally, I'd do the following:
1.) Get a new regulator
2.) Get a new rectifier (I've used the aforementioned Oregon Motorcycle bit with good success)
3.) Get a new battery.
Combined, the parts are pretty cheap and should solve your issues.
--Chris
I replaced the battery and rectifier yesterday before I posted, and tried unplugging the regulator with no change in result. I'm starting to think that the reason my voltage is still around 12 when running, is because my headlight is on.
I'm going to re-time, adjust point gap, and valve tappets. Hoping that's it...
-MK
While timing, point gap and tappet clearance are all important bits of maintenance they won't have any effect on your charging system. If you're not pushing 14.5v at 3K rpm you need to figure out why or you're never going to have a reliable ride. Wish I knew more about your specific system, but the only bike I've ever gone through all that with was a KZ650...
I think it might be due to the fact that the headlight was on. I hear there's little to no voltage increase with the headlight on...
What voltage does it read through the rpm band with the headlight turned off? My kz650 doesn't charge as well with the headlight on either, but it still climbs up to just shy of 14v. I'd be really leery of riding it if it's not charging. Eventually you're going to find yourself stranded somewhere because the battery shit out on ya. (Ask me how I know that...)
I'm going to re-check voltages as soon as I get her running and idling.
After a lot of thought and contemplation, I think this is what happened:
When I got the bike, it ran great. I rode it on short little jaunts, and ALWAYS had the headlight switch 'on'. I think I killed the battery doing this to the point where it wouldn't stay running. Maybe the rectifier was on the fritz as well. The problem is, I started taking readings and changing variables (points gap/timing), without replacing the battery. Once I replaced the battery, the bike still won't run because I messed with the points gap.
So I'm going to re-time the bike today, and hopefully that fixes it. If not, I'm seriously at a loss.
I do have one question though. I purchased a late model Ford voltage regulator per the part number listed in the $50 mod thread. Which wires go where on the new reg? I couldn't find pictures or instructions.
Thanks again for all the help.
-MK
Re-timed bike, and it fired right up. Thanks again for all your help. Bike charges as it should.
-MK
-MK
MK, Congradulations.
How about a quick list of everything you have done. Did you figure out the Ford regulator?
Troy
Adjusted points gap, timed bike, replaced battery and rectifier.
Haven't hooked up ford regulator yet...
Hey man,
I am getting pretty much the exact same problem... how is your bike doing now? have you made it further then down the street yet?
Well, my charging system is fine. The new battery took care of that. My timing took me quite a while to get perfect, but now gap and engagement/disengagement are perfect. Now I have what seems like an intermittent oiling problem. Sometimes when the engine warms up, I'll get a squeeling noise, and the engine will "seize". The kick start is hard as a rock and I can't get it to kick over, and the electric start barely turns the engine. Once it cools down it's fine, but I'm going to have to pull the RH cover off and inspect the pickup screen/oil filter to make sure nothing's clogged.
I haven't been able to ride this thing more than 20-30 miles since I've bought it. I actually considered selling it a few days ago, but I'm going to try to work through this for the time being...
Good luck with your bike.
-MK
