New handlebars, bike wont start. Kill-switch problem?
  • Thread starter Thread starter KYL3
  • Start date Start date
K
KYL3
Guest
I just couldn't leave it the way it was..
The bike is a 71 cb50. The bike was running fine, the electric start would almost make it turnover, but didn't seem to have enough battery to start it. The kick-start would always start the bike, 1st or 2nd time. Being young and wanting some super cool handlebars, I put drag bars on. I couldn't feed the kill-switch, electric start, and headlight wiring through the original bars, so i just cut them, and planned to solder them back after the new bars. The drag bars are on, the headlight is wired, but the kill-switch and electric start on not wired. Ran out of time, and put everything together. The throttles on, working good.
My question's are
Should the bike be able to start without the kill-switch wired up?
Could the loose kill-switch wires be touching something, not allowing it to start?
The battery seemed super drained after testing all the turn signals and lights, but shouldn't it still kick-start on a almost dead battery?
So.....bike was running, you cut some wires and now the bike doesn't run....
What do you reckon? ::)
Charge the battery first. While it is "possible" to kick over on a dead battery, it's far from easy.
lmao ;D that was good
I was just curious if i should be able to start the bike with the kill-switch unwired. I'll charge the battery, see how that does. Then mess with the kill switch wires and see what happens.
I'll update if i find out anything new
Thanks guys
The kill switch depends on the bike - some are normally open while others are normally closed.
Charge the battery and wire up the kill switch - then are what happens.
Kill switch wired, and now the bike is kick starting first try ! I Broke a part of the switch inside right side headlight controls, so now going to use a universal switch, and swap out some wiring.
Its settled, the kill-switch must be wired to start !
Thanks guys !
