hi, can anyone help, frustrating mixture problem, i think.
tried to put in the oo racing jet kit and couldn't get the bike to run right. ok at up to half throttle, about 4500rpm then misfired and wouldn't pull at all, and on throttle back would cut out rather than idle
decided to go back to the original needles but with exactly the same results. revs to about 5-6000rpm this time misfires and on throttle back still cuts out
have spent all day going round in circles, rich, lean, in between and back again
did take out the internal slow running needle inside float bowl to check and clean and may have miscounted turns of the needle. does anyone know the rough factory settings for that thought i counted two turns but could have been 1.5 or even 2.5 arrrgh :-[.
needs choke to start then choke off and runs at idle of 1450rpm give or take 50 rpm (i'm using a digital inductive tacho), using 3.5 turns on idle screw on side of carb and 2 on the fuel jet on the bottom of the carb but think that the miscount on the internal idle screw may be the cause of my troubles.
i have the skyteam decat pipe on and egr delete, they went on before the jet attempt and i was running up to about 55mph so was well pleased, now i seem to have well and truly bu****ed things up :-[
any help would be greatly appreciated, as i was running great before and am now going better backwards
