New muffler mounting issues
AzHonda
Coast to Coast
I have two new reverse megaphone mufflers for my 360, It came with one set of reducers.
HOW IN THE HELL DO THESE TIGHTEN DOWN TO THE EXHAUST PIPES!!?? I can only get two of the three reducers in the tip of the muffler. The third one makes it to tight to get over the exhaust pipe, with two in there, the exhaust clamp will not tighten it down enough. These pipes look damn cool on the bike. Just wish I could get them hooked up.
What am I doing wrong? Tips? Does this even make sence?
You may have to expand silencer to fit with 3 adapters or, better bet would be find some thick wall pipe and use single adapter.
The universal fit usually fit nothing properly without extra work
Look at "exhaust pipe expander" at your local auto parts store. Some of the chain auto parts places will rent such tools to you for free.
It seems like the expansion would do the trick to get that third reducer in. I'll check one out today.
Just be careful not to crack your pipes :) I've had this problem in the past and never solved it. Last set of silencers I got were a perfect match for my headers - I don't even have to clamp them at all and they don't leak.
Welding collars onto the headers might be an option as well to ensure the header pipe remains strong. Just don't expand it too much - only so much stretch in metal ;)
I picked up the same kind from DimeCity for my XS and ran into the same thing . took some metal stripes and made half sizes smaller then the larger spacer but bigger then the middle spacer and bolt it right up .
So, metal strips as in thin sheet metal?
Frog said:
Is it possible to grind or file the 3rd spacer to fit.
I dont think so. I know the beer can thing sounds funny but that is about the thickness I probably need.
Dont think you would want to grind them as it would be hard to keep a constent thickness all the way around . with the beer can or sheet metal all you need to do is cut them to size and you will never see them...
Beer can shims are a long standing tradition in motorcycling. Handlebars, mufflers, clipons... 1 beer can goes a long way.
Re: New muffler mounting issues....Update
Not that anyone might care but here is how I fixed the issue.
Cut a strip of 20 guage Stainless sheet and wrapped itinto one of the reducers (largest one) and it gave me a perfect fit.
Actually, we do want to hear how problems get solved. That's how we all learn from one another, that is, the ones who are not too arrogant to listen. ;)
Even better than beer can!
Whats funny is I did the beer can thing like you guys mentioned. It worked but this just seemed cleaner.
