new project...called the old goat
need4steed
Active Member
I just picked up a 73 cl350. its been sitting for the past 15 years. 11,xxx miles on it. The seal on the right side blew and shot oil all over the place. (words from the original PO) I still have to check it out and go over the whole thing, but not bad for trading a DVR....
I will get this project started after i finish the GL500
just a little update. i was able to score an old superhawk tank in good shape for 12.50! damn that tank is going to look damn good.
Yup, front mounts need to be moved forward and up. Rear mount needs to be fabricated.
I got the tank and it is solid all the way around. I just put it on the frame just to see what it will look like and it is a perfect look.
Now i just need to finish the Gl500....
oh yea it is. all i didnt was set it on there to see what the potential look would be. I have lots of work and fabing still to do.
For the love of God man, turn those tank badges around. The wings point forward! Sacrilege!
It has been a long time, but not that i have finished the GL500 i have been plugging away on this little gem.
What i have done so far is make a rear cowl completly out of scratch. i made all the tabs to mount the tank ( still have to level) and installed a brace in the back right between the rear shocks. I plan on running on the track when i am finished and i heard this is good for making it a little bit more stiff. I also took off the brackets for the front pegs.
i made the cowl by cutting an old tank in half and reducing the width to get the desired look. I think it has good flow and look to the bike.
the next thing is to do is rebuild the forks and rear shocks. any tricks on taking the rear shocks apart?
Glad to see this project back on track. seat fab looks good and good with the tank. I know you are still fitting but I'm not digging that tank on that frame. I'll wait to see what you come up with though.
Hey guys, i know it has been a long time since the last update. I have been doing nothing but riding my GL500. The past two weeks i have really gone to town on this bike. I rebuilt the motor and got the static timing and tappets adjusted. I am just stuck on the wiring. I cant get any juice to the headlight when i wire it by the diagram.
The starter Solenoid has the two terminals. the one side is connected to the + on the battery, while the other has the main line with the fuse and wire going to the starter. When i turn the key nothing comes on. But when i put the main wire (color red with the fuse) on the same terminal as the one going to the + side of the battery the lights work no problem. do i have a bad starter solenoid?
Hope that makes sense.
here is how she sits right now.
