Trevor May
Bought a R/R from sparck moto and it's time to install! The new unit replaces the two separate old ones.
Almost bolt-on! The old regulator bolt pattern is 1/4" narrower than the new combo unit. Well, I know how to fix this! Start by drilling the spot welds with my special attachment.
Then cut off the spot welded nuts with a dremel-style tool and cutting wheel (or 10).
Use same knock off tool to grind the holes wider on the bracket.
Well the nuts back on the bracket and the bracket back on the battery box.
Decided that I didn't need the attachment for the old rectifier so I cut it out with the spot weld cutter and painted it with under coating, because that's what I have in my cabinet for black paint.
Tomorrow I will see if it works. I've done more projects than this, but I haven't been very good about documenting my progress. Hope you like!
