Newb from Charlotte, NC
Bama704
Hey yall, I finally joined up o this forum as I'm hoping yall can answer some of my questions later down the road. I am also on KZrider.com and they have been great thus far. I bought a 1977 KZ900 with low miles back in late September, have been doing some tear down on it and replacing parts as I go. Found out not to long ago that the PO replaced the carbs and put on ones from a 1975 Z1, 28mm carbs instead of the stock 26mm. Having fun as I go slowly, going to make it into a Brat style. Any help along the way is appreciated. Thanks in advance.
Looks like there are a few members from Charlotte, NC here which is nice to see! Any with old Kawasaki's?
before you go changing it to much
just give me a call and maybe i can buy it from you and enjoy it just the way it is
Not going to be cutting the bike up, will eventually do some detabbing but no cutting of frame. I am not going to sell this bike but am looking forward to moving along further.
Those KZ900's are getting to be pretty rare, and one that looks to be relatively complete and in pretty good condition could bring some decent money. It would be a shame for a collectable bike like that to be cut. (that includes cutting off tabs) My advice would be to sell it, buy a much less rare KZ1000, which looks nearly identical, and use the all the left over money to fund that project. In the end its your bike, so do what you will, but know you might experience some backlash from other members for cutting it up, particularly over at KZrider. Also, do not paint over the original paint. Looks like a good cleaning and that would easily pull $800 alone on ebay.
what he said
find a good body guy and let him clean and polish the tank and side covers you would be amazed
i have a retired neighbor that does mine for me with polishing compound he mixes himself ad stuff looks new
maybe not perfect but now there is a huge dollar preference to "survivor" rather than restore
dont cut it up i will help you find another and buy it from you if need be
Welcome!
I'm in NC as well, and have a 77 KZ900A5.
I have some fairly extensive modifications, but no structural changes.
The 77 was the last of the 900's, and most documentation agrees that they simply used up all the remaining 900 lumps they had as they switched over to the early 1000 motors.
The frame is exactly the same as the 1000's and they did not have some of the rarer early Z1 bits on them from the factory.
If this was a 73 or 74, I'd agree that selling it to a purist would be smarter in the money department.
But a 77 900 isn't all that rare.
That said, any stock items you do not wish to use may bring a decent penny, so don't molest them when you dismantle.
Again, welcome!
Also, that's not factory paint, fwiw.
And keep that oil cooler. The old lumps tend to run a smidge hot and benefit from that cooler.
Thanks Bozz, I appreciate it. Where in NC do you live? From what I have learned, just like you said, the 77 KZ900 nobody wanted to buy since the 1000 had just come out. Everybody was already moving past that model, and yes if i had an earlier model I would probably sell it to somebody who wanted to keep it stock. I thought I had the stock paint on mine, if not what was the stock color???
With my KZ900A5 I want to have some fun with it, have already cut the front fender to make it shorter, have done a 530 chain conversion and gotten the sprockets as close to stock ratio as I can, drained and replaced all the oil with a bit extra for the oil cooler (which i'm glad the PO put on there). Have had to remove the rusted out muffler, cleaned and replaced all gaskets on carbs, which are from a 75 Z1. I do however want to order the K&N RC-2222 dual pods to put on the bike. Had to cut the rear shock mount bolt off of the tab because even a die wouldn't bring the threads back to life, so I drilled through the tab and then tapped through so i have a recessed allen head bolt on there now.
The hardest part for me will be on how to clean up the electronics underneath the side panels and find somebody to make a seat pan and a box to house the electronics under the seat. And to find a place for the battery.
I have attached what my inspiration is.
I realized i have never seen a photo of a stock the kz900A5. what color/stripe combo is going on there?
also if that is original paint, but not correct to the model, i still think you would be better off selling the set complete and finding a tank to repaint. more money for your build.
I stand corrected!
The striping threw me off.
That does appear to be stock 76 KZ900 paint.
(77 only came in red & blue)
The 78 KZ1000 had a green option, hence my confusion.
You'd think after 40+ years I would learn to shut up.
