mariob1278
yea its fast!!!! NO!! you cant ride it
I just picked up a 76 cb750 ss for really cheap because it wouldnt start and the brakes where seized. in a week i got the brakes all sorted and she started right up once i changed plugs and noticed that the harness plug behind the ignition switch was loose. i did a full oil/filter change , cleaned out the tank/carbs and she starts in a few kicks and idles once warm no problem. now we get to the problem..... it has a clutch which is so hard im begining to doubt my manhood. i checked the cable for any dmg and lubed it up and nothing. i mean i go down the block on this thing and my hand starts to cramp up after a few sec of holding the clutch. is this a result of an aftermarket performance clutch because im suspecting its been worked due to a 2mm shim on jugs and a dyna iii electronic ignition no to mention it sounds like a monster compared to friends 750?? any help would be greatly appreciated ?? pics are crappy sorry
