NEWBIE - 1970 Kawasaki G3SS
SalVW
Hi-Ya
I'm the FNG. (f'in new guy)
My life has gotten too boring so I picked up a tired old 1970 Kawasaki G3SS on CL for peanuts. It ran for a minute but now it's stuck in 4th or 5th gear. The seller had cleaned the carb, replaced the plug and fluids and that's about it. The wiring is AFU! And the tank is full of rust :( tho there is a fuel filter on it.
I know NOTHING about motorcycles but it's high time I learn and what better bike than this little P.O.S. I've cleaned out my garage to make some space and now it's time to fix this thing up. I was thinking of starting with the wiring because they only way to turn off the engine is to stall the bike when it's in gear and I think that may have led to the clutch/shifter getting stuck but I have no idea. Anyway I've got to start somewhere right? I found a copy of the shop manual and parts manual on eBay so I'm thinking about buying those.
Any and all comments, tips, tricks, suggestions and advice is GREATLY appreciated!
Thanks!!
I'm in Portland, Oregon btw
Welcome!
Found a 74 G3SS being parted out on one of the normal places I use for sourcing classic motorcycle parts. Not sure on the rules about linking sites in posts yet as I'm new as well, but shoot me a message if you want me to send you the link. Not 100% sure on the specifics of if 74 parts will direct swap into your 70 but may come in handy when you get down to trying to fix the transmission issue, depending upon what it ends up being. Good luck and have fun!
Sigurd8404 said:
Welcome!
Link away. DTT kinda prides itself on not being one of those "read the rules" joints. Most
y because there aren't really any rules ;)
Sounds good. So OP, I source a lot of stock classic parts from www.bikeboneyard.com, it's basically an online junkyard for a shit ton of classic bikes which I believe is physically located in Montana, but will ship pretty much anywhere. Here is the link to the 74 G3SS being parted on the site http://bikeboneyard.com/74%20g-3%2090.html, in case you need it.
That is a cooooooool G3! I have a newer KE100, basically the same bike but in dirt form. Rotary valve FTW!!!!
