Newbie CB750 Cafe Project
I hate electrics....
This will be replaced by a nice round headlight if all goes to plan :)
Toll the front brakes off while stripping the electrics:
Finally the loom is out:
Dismantling the front end:
Garage could pb do with another tidy up at this stage...
Just need to take the yokes off now but need to buy a bigger socket :(
I manage to get a bit further this weekend. I started removing the last section of the frame, the yokes:
Now the frame is all ready for cleaning, welding and eventually powderconating :)
Here is another little project that I am also working on (as and when time allows), a Pasini Mini Moto:
Back to the CB750 :) I started the "massive" task of cleaning / degreasing the filthy engine:
Until a nice new engine stand was delivered :) :
Time for another re-organise of the garage to make some space allowing for the engine to be worked on easily (enough):
I found an old table in the cellar to mount the engine on:
I started stripping the top end of the engine to see what sort of condition things are in:
All of the center head bolts were sheared off :( will have to replace these (not a great start) ...
In my "novice" opinion, so for so good and the chais seem to be of good / correct tension ...
time to get the alignment right before moving the cams, this is the part I was most worried about :S After a lot of reading and asking around I think (hope) I did it correctly ...
1st one off
Is it ok / normal for the connecting rods to have a little play (left and right) ? All of them seem to have a little amount of play, with the second rod in from the left left (looking from the front) having a tiny bit more than the rest ...
At this point, seeing although I am this far (and the bike had a knocking noise coming from the engine when running) I thought it made send to go the whole hog and also check the bottom end of the motor to make sure there are not "bigger" issues related to the camshaft / connecting rods etc before I continue ... it's also pb best as the bike has 60,000km (40,000 miles) on the clock and it appears the the previous owner(s) did not look after it too well :(
Now I have hit a wall and conta continue until I get / make a tool to take this nut off:
I did not get too much time on the bike this weekend :( due to catching up on some important jobs and watching the England France Rugby game :) I did however manage to get a bit done.
I tool Honda tool arrived during the week, but sadly was the wrong one (was too small). They sent me the wrong part (with the wrong part number) so it has to go back... This pretty much stopped my weekends progress :
I did however (instead) manage to get a bit further with my MiniMoto Project. I primed, re-sanded and re-primed the frame and wheels ready for paint:
I eventually got impatient and took a hammer and long screw-driver to the clutch bolt :S and decided it would be easier and faster to simply replace the bolt with a new one on the re-build (it looks although someone has already take a hammer to it anyway):
I could not seem to get the alternator rotor off... After a while of trying I thought I would leave it for now and do a bit a research before I broke something :(
As I am now a bit stuck, a lot of the engine is already apart and space in the garage is slowly getting less I thought it was a good time to have another clear up and organize everything... I have learnt (in my case at least) keeping your working space tidy and organizing your parte and tools make the whole process a lot easier ....
