Newly rebuilt CB200 engine weirdness.
diesel450
"Fast with a past"
DTT BOTM WINNER
Okay,
So I got my 200 running. top end was honed and reassembled with nearly new pistons and new rings. Motor fired and ran great all through the jetting and tuning process with no problems. finally got her out for the shakedown ride and things started fine. still needs a little carb tweaking but the motor ran great for about 10 miles then after accelerating from a light the motor stalled. there was a lot of smoke coming from the breather tube. exhaust not smoking at all. I was right down the street from a buddy's shop so I stopped there we started it again no issue. tweaked the carbs a bit and off I went. I went about another 5 miles and it was again running great, then all of a sudden it just quit. the bike didn't lock but the motor just stopped running at about 30 mph. No electrical issue. when I tried to restart it the kicker felt like it was stuck in molasses, no weird noises nothing crunchy or metallic. just felt like a big bucket of goop. I pushed it back to the shop. thank god its a 200. when I got back about 10 minutes later and tried kicking it and it was locked. I could shift through the gears but the top was stuck. I put it in gear and rolled it back forth a few times and it came free. I let it sit and then kicked and it started like nothing was ever wrong. What gives? I had the bores and pistons measured and it all was supposed to be good, does this sound like bad pistons/rings or simple overheating or what? forgive my inexperience please. could use a hand here.
Sorry man, i dont have any "sage-like" advice except the breather tube was probably just burning off excess oil from the rebuild.
I just want to keep an eye on this.
What it sounds like is a partial seizure. I hope it's something less serious, like a blockage in the fuel tank filler cap causing it to run out of fuel. It's that sticky fudge feeling that sounds sub optimal.
How hard were you running it at the time and how were the new bores broken in?
Pop the plugs out and take a look. They may reveal something. if not, I'd pop the top off and see what the bores look like.
I was afraid you were going to say something like that. I'm almost certain its not a fuel issue. Bike was not being run hard. I was trying to vary rpms up to like 6K. speeds not exceding 60mph. Everything I've read about breaking in a bore is to run it at varying rpms as much as possible and go easy on it. No?
I'll check the plugs, what am I looking for? Probably a lean condition?
Yeah, a big bucket of goop with nuts and bolts in it.
Good thing I love building this bike. :P
clutch probably adjusted a bit tight, bedded in and was slipping when you tried kicking it over. (common after re-build, even I've done it)
Probably running a bit lean and something got tight.
If you had stock bores honed and fitted old pistons there should be plenty of clearance.
I usually run around 0.0015"~0.0017" clearance on my motors, irrespective of finished capacity, (378cc ~860cc twins)
200 twin can probably run down to 0.0008"~0.0012" without any trouble (smaller pistons just don't expand as much as larger ones)
You have checked oil flow to top end?
Pistons seizing are relatively uncommon in my experience, cam bearings and rockers are far more common
pull valve adjuster caps and start motor, should have a LOT of oil in 20~30 seconds, Q.D. method (Quick and Dirty ;D)
I wouldn't worry about whats coming out of breather, unless there is a lot of oil.
You did have rings in correct positions? (you wouldn't believe the amount of times I've seen the middle ring put on upside down in top position, mechanics thought it was a 'ridge dodger' ::))
Okay that helps, I was already cruising egay for pistons (that whole sentence is just wrong. not that there's anything wrong with that.) ::)
That makes sense to me on the clutch thing.
I'm pretty sure the rings were right but its been a while now since they went in.
as far as oil flow goes if I don't get a bunch of oil what is the next thing? how do you fix that problem?
So, if things were lean (read hot) should the answer be, re-adjust valves and richen things up?
Oh, hey! PJ if you need help with that title let me know!!
I'll let you know when I'm able to get around, there was more to do than I expected before surgery so didn't get near tag office
A guy on the hondatwins forum mention checking the cam chain tension. makes sense that you'd want to do that after a rebuild once you get the motor hot. All this is happening at about the same point, when the motor gets fully hot after about 10 minutes of riding. So, i'm hoping its a matter of adjusting a few things. we'll see.
Okay, I dug into the bike today, plugs looked fine nice even tan color to them. I adjusted the cam chain, there may have been a slight problem there as the lock nut was stuck a bit so it may have been mal-adjusted. I did PJ's QD oil test and now have a dirty shop floor. ::) Though it didn't spit oil out the intake side just the exhaust side. rocker arms looked well oiled though. Bike started right up and ran fine. after one stall while it was still cold I did notice that sticky kicker a couple times. I backed the clutch adjustment off a couple turns and haven't noticed it since. I did not road test it yet but will get to that tomorrow.
