No Damn Tail Light.
PHeller
Coast to Coast
First my running lights went dead. I jumped at the fuses to solve that problem.
Now my tail light is dead. Bulb works, brake light works, but no running light.
Brown is the tail light, right? Where does it get it's power? The ignition switch?
what bike?
If its a cb350, yes it's the brown one, straight from the ignition switch. Check the ground. Clean the contacts in the bulb socket. Headlight working? Battery charged? Move the headlight Hi/Lo switch back and forth a couple times to make sure it's making good contact.
The high/low beam switch sometimes finds a position in between the two and doesn't work, but usually switching it back and forth a few times lights up the headlight, along with the running signals.
That's what gets me, the fact that I'm getting a headlight and running signals but no taillight.
Turns out it was a poorly executed reconnection of the ignition key switch. Someone must have cut it off (don't know why because it matches all the other locks on the bike), and then put it back together with crimp connections. The crimps were horrible, and were falling apart.
The headlight issue is still a mystery, and still powered via a fuse jump.
