No headlight or taillight randomly
Jayowen
Active Member
I have a 76 cb550f that runs perfectly but the headlight and taillight stopped working randomly. Lights come on in park mode on the ignition. Replaced ignition switch but still no lights in run mode on the switch. :-/ any help would be awesome.
Which of the 5 wires to the ignition switch should have power?
exactly. so we know that red to black works cuz thats to the engin power. but no power getting to the brown/white brown combo.
On the left hand controls I took out the turn signal wiring. Would that cause an issue. That causes a brown white to be disconnected. Right hand doesn't have a brown/white
There should be one coming from your high/low switch. You're looking for other brown/white wires. Ignore brown for now.
Hi/low switch works on park in the ignition. It has white black/yellow and blue. Only other brown/white I have is the one for the tach and speedo lights and when I plugs those in still no power there. I lugged every thing back in and still no power to brown/white
One of your controls (left or right) will definitely have a brown/white wire. It'll be the side with the headlight on/off switch.
Weird.
Anyway... you can bypass all that stuff by just plugging a brown/white into any spare black wire.
Sorry... Brown/blue is what I meant. Not brown/black.
Plug that spare brown/blue into a black wire.
