No Spark Dude
Pmbjngls22
I'm not getting any spark from the plugs. My battery is "technically dead" but I have always been able to kick start the bike. Using the ignition switch always seems to take all the power that I have, so I usually just kick start. However, I've jumped the bike from my car and I still get no spark even though the bike is turning over when I hold on to the ignition switch...the spark plugs look fine and the coils test out okay. I'm not electrically minded...what's the next thing I should do. Also, when I bought this bike the electrical system was a little messed up so I had to rewire some stuff. I do not have a fuse ANYWHERE, so I'm a little worried I've finally damaged something. What should be my next step? Does any of this make sense?
You can put it in your signature along with the build thread.....
But honestly man, there is so much to check out that it's hard to pinpoint what your problem is. Find a wiring diagram, get a multimeter, and start following connections. It sucks, I know.
Just want to point out: it might be easier to buy an unmolested harness on eBay. At least then you'd know what you're starting with.
Well. I just noticed something. I'm not getting any kind of voltage at my points, but I do see some kind of spark coming out of my kill switch/ignition controls when I hold the ignition down....That doesn't seem right to me. Maybe I have a short of some kind?
Maybe you do...but Big Rich had it, I think. No way to diagnose but careful testing, and you'll want to have a good understanding of the wiring.
Okay, so I think I have narrowed down the problem area. I have 12v of power going to my right cylinder points, but not my left cylinder points. Also my left coil is getting kinda hot. I switched coils and I still get the same result. I even switched the blue and yellow wires that come from the condensor. Any ideas of what is happening?
On your bike don't the coils draw power from a common wire?
Do you have 12V to the coil? (Black and white wire)? Coils are a common feed, but the connector is a dual connector. if you have power into the coil, points open (check) and no poer coming out, then the coil is dead. If with the points open you have 12V out,t hen the points need adjustment. Adjusting the points means adjusting the timing, so you will need to follow the timing procedure carefully. Most get it wrong the first time....
Here's a good site for the wiring diagram
http://oldmanhonda.com/MC/MC.html .
Make sure all your grounds a good . I had a similar problem when I got mine .
