No tailight!
sphynx88
Alright, putting my bike back together again and I cannot understand why my tailight is out. I have triple checked the connections behind the headlight, bulb is new, fuse is new. Getting power at fuse and both wires brown, Gr/Y to the tailight have power. Reading bulb ohms is good. I have tried pressing both brake switches and the headlight is on but neither filament is working.
Any suggestions would be helpful. See the wiring diagram below for reference. The brown solid wire to the bulb (at the front) in the diagram doesn't exist.
Hook your tail light to power and ground and see if it works
Bad ground would be my guess. If you're getting +12V on the running and brake light wires and the bulb is good, I don't see anything else it could be.
Alright problem solved, I was way over complicating it. What else is new. Matt you hit the nail on the head, the ground from the light was disconnected just enough for me to miss it on my first pass,it's a damn shame I took off the tank and headlight. Thanks for the help guys.
