Noob Kill Switch question HELP
indianajonze
Active Member
I'm worried I damaged my kill switch during a handle bar replacement. I took my electric start button out completely because the spring broke (bike will be kick only in a few weeks anyway) so i've been attempting to start the bike by grounding the yellow and orange wire to the handlebar to engage the electric start, but, its not working. The electric start is being engaged but it just wont actually turn the motor.
Is it possible that in messing with my right side switch housing electronics that i've permanently engaged the kill switch? If the kill switch is in the "kill" position, should the coils, starter etc. be getting power at all?
How can I run a simple diagnostic on my kill switch?
NOTE: The bike is a work in progress so there may be a multitude of other reasons it wont start (carbs, dirty gas, old plugs). I'd just like to be able to rule this option out.
So long as you know which colors are the two wires coming out of the kill switch you can contact each of them with the two leads on a multimeter. Turn the multimeter to the ohm setting (looks like Ω) and you should get a very low reading (close to zero, probably less than one) when the switch is set to run. With the switch set to off, the reading should then change to something very high (off the chart). Digital multimeters will usually display this as ---- or something similar.
Okay this seems simple enough. I have a 1972 CB350 (K4) so I'm pretty sure the kill switch has a black wire running power to it and a black & white wire running from the kill switch to the coils. So these would be my two wires?
Is it possible to test the power coming from the kill switch? As in, test the black and white wire running from the kill switch? It should read 12v and 0v when the kill switch is in "kill" positions right?
The kill switch shouldn't affect the starter motor operation at all. All it does is supply/cut power to the coils.
If your starter is engaging, but not turning the motor over, you more likely have a weak battery. Or a loose connection between the starter button and the solenoid and/or the solenoid and the starter.
Well, you could have a weak battery but considering that you suspect a kill switch issue, I'm going to guess its that. With the kill engaged, your starter WILL crank but your spark plugs WILL NOT fire. Unless your starter is just making some god awful whining sound, then it is indeed turning the motor over.
So, if your stater is engaging but you aren't getting ignition (and it's not a weak battery), then you might have the kill switch stuck on.
Unless your kill is set up differently, it will be one wire from the CDI (so idk what it is if you have points) that is connected to a ground wire to enable the kill. all you have to do to diagnose this problem is make sure that those stay disconnected and that you aren't accidental grounding the hot one.
A weak battery is very possible. The bike hasn't been run or had the battery charged in weeks. I took voltage after the kill switch and when i switched it to "kill" it dropped to zero which seemed like a good sign.
I'm also currently missing my starter button, ive been just touching the yellow/red wire to the bars to engage the starter. That may have something to do with this all. I'm going to put in the new kick spindle any day now and go from there as far as why it isn't starting.
