Hi bros
Picked up a CM400 T from 1981,wanted one from my birth-year! 8)
I don't have much experience in building bikes so any help will be welcome!
I have allot of questions regarding the transform of this bike into a cafe racer.
I want do this project in a few stages!
I want to remove the air filter and place racing kelks onto the carbs, but I have read that this is not possible using the standard carbs! Is this right? Witch carbs should I buy? I'm looking to keep this build a bit price conscience so if possible to keep stock carbs !
I want to place the battery out of the triangle, so I guess in the back of the seat!
The question that I have If I replace it with a lithium ion battery, whats the minimum Ah that I need for the bike, the stock lead battery is 12V and 12Ah!
http://www.shido-batteries.com/html/technical-specifications/index.html
If I look at Shido the battery can be replaced by a 4Ah ,LION battery.
But needs the battery be so big or can I go for the smaller battery,( lighter, cheaper, easyer to hide)
I readed somewhere that one had replaced its CM400 battery with a DEWALT battery pack from a cordless drill!
Is the LTX4L-BS LION -S- 12V/ 1,6Ah /CA 105/ Wh 20 big enough to use ? The CA in A what does this mean?
http://www.shido-batteries.com/html/downloads/shido_cat_eng_2013.pdf
The wheels, I like the comstar wheels but wanted the same size wheels so I bought 2 wheels from a CB400N so both 18 inch ( does this give problems?) because original wheel is 16 inch!
Do I need a different gearwheel?
The engine I don't want to open this because I don't have the knowledge and the guy I bought it from said the block is fine!( maybe in the future)
I see this as a getting into cafe-racer project!
I wanna keep the bike street-legal, so I need the light but replace the side light with smaller led lights ! I wanna keep the front light, think this look ok!
The instrument panel is something I wanna keep in the first stage!
What do I need to do to the back suspension can I keep this stock? How do I test If they are still safe? I have the plan to place the fork feet 1- 2 inch trough the (front-plate, don't know the word for this) so I can put clip-ons onto this! Or is this a silly idea? Do I need to buy new front fork for safety?
My first plan is to get a new oil filter and some new oil into the block, does anybody has good suggestion on witch oil to buy or what to look for.
http://www.goparts.nl/onderdelen.asp?G0=300000001&G1=15CC00001&G2=141HO0001&G3=141HO3410&T0=Slijtage+-+vervanging+onderdelen&T1=Motor&T2=Honda&T3=CM+400+T&D=Sfam
The front break disk can I put holes into this or is this a stupid idea?
I'm just getting started so much questions yet to come!
Thanks in advance for the help ;D
