surfish95747
Active Member
Hey guys I have my engine out of the frame for cleaning and want to turn over the engine. Which side cover do I take off the get to the bolt in order to manually turn over the engine. Like I said NOOB question. Thanks!
xb33bsa said:pull the sparkplugs out as well otherwise you may just undo the bolt when turning over
generally not a good idear to turn it backwards either![]()
plagrone said:Bah! Jb weld and sanding! Not really any oil pressure down there, no point in buying a new one, especially since it's on the bottom bolt. You'll be the only person ever sees it
xb33bsa said:a buddy of mine dropped his 900f at 2mph and that same damage occured as well as a fried stator
VonYinzer said:That crack and those deep scrapes mean the bike was layed down. Go over the motor very carefully and make sure there are no other cracks or broken bits.
surfish95747 said:Well I turned it over and it's smooth as a babies bottom. I did a compression test with the engine out of the frame and each cylinder reported exactly 30 psi every time. Being consistent is a good sign of things working right on the inside, right? I'll probably be buying a new stator and regulator/rectifier after it's all put back together, just to have new ones. Thanks all for the help!
if you are turning over by hand with a wrench 30 may be all you can get hahahah but being all the same is good newsplagrone said:Consistent is good, 30 is not. If you meant 130 then that's within operational limits. Otherwise, set the valves and try again. Excessive valve spacing can cause low compression readings.
Read up on how to do a proper compression test. You'll want to do this now whole engine is out of frame
