I got the seat under tray back, with its battery recess welded in place. Now all it needs is a Ballistic battery..
Also made a start on the new rear set mounts. I used a scrap piece of 10mm alloy and drilled the peg and frame mounting holes first. Then took it home to check it fits the frame ok, so now the rear master cylinder can be mounted, and the bracket shaped. The other side is easier to do, except it'll need a new shorter shift rod making. The socket head bolts will be counter sunk a few mm and their heads machined so they are almost flush with the plate.
