Novice reworking electrics
leprechaun_sean
CJ250 'Rising Sun' project
Giving this electric black magic a blast on my CJ250.
I'm taking off as much as I can (indicators front and rear, speedo and tacho including lights, idiot lights) partly with the intention of clearing up the bike aesthetically, and partly with the intention of much further down the road installing a battery eliminator, so I'm trying to bring the amount of wattage used down.
So, studying a wiring diagram, I'm planning what to snip and where, because I want to do it properly.
As you can see on the one below the rear turn signal is wired into the taillight. If I remove the indicator, will it break the circuit to the taillight (leaving it "open" I believe the term is) or will it be ok?
Noob question I'm sure, but I'd rather know!
Cheers guys
It's more like they share a common ground. You can remove the turn signals, but make sure the taillight still gets a ground.
Start with unplugging what you don't need/want and remove wires from there. You can simply cap off the unused leads and tuck them back into the harness if you don't want to go through and completely remove the wires.
Cool, cheers man.
I'm presuming as the indicators at the moment use those little bullet connections, if I disconnect them they are essentially caped off as the have that plastic covering around them?
Yes, but adding a little electrical tape couldn't hurt to prevent any shorts in the future.
leprechaun_sean said:
Nope, i asked last time I was there. I presume that's why on your theory you are asked about hand signals :)
It's a dangerous road to travel when removing your turn signals and relying on hand signals. Keep in mind that you may know the proper hand signal, but does that 16 year old behind you know that your LEFT hand up and elbow at a 90° angle means you are turning RIGHT? Don't count on it. Plus it takes your hands away from the place you need them when turning; on your handlebars.
Just lookin' out for you, it's your bike and your safety.
In the UK, you use your right hand to signal right. There is no holding the left arm up at 90°. ;)
Hahah, didn't notice OP is in UK, should have caught it with the "cheers".. :P
STILL. Sean as you can see by the thread on your rear brake setup, some of us are concerned with your safety. Being safe usually means taking the route that cost more, is less fun, more time consuming, but some of us have learned the wrong way and really wish someone would have firmly encouraged us to be safer.
You technically don't need any lights whatsoever for UK MOT. Just a working horn and a speedometer (which won't be tested anyway)
The tester will put an advisory note on saying "no lights fitted at time of test"
Any switches, etc will need taping over prior to test, if no lights fitted.
Bless you all worrying about me ;D fear not, at this rate the bike won't e finished for many decades! But in all seriousness, I can road safety very seriously (actually part of a road safety riders association, pretty rad eh?). I've another bike (gpz500/ex500, whichever you prefer) which I used for everyday riding, and on that I'm overly cautious on all things road safety, this bike is going to a purely sunny, once in a blue moon adventure :) but cheers for the concern guys, I would like nothing better than to be told if an when people think I'm going wrong :)
I was tempted to go down the no lights at all route, but you can only have a daylight mot then (obviously) and I know I'll regret it on a warm sunny night! I heard you still need a brake light for a daytime mot though?
