Finally got my handlebar wiring all sussed-out and run through my clubman bars, but I'm having an odd issue I wonder if anyone else has run across:
With the clam-shell housing off the bike the turn signal rocker switch works fine, but when I clamp the housing to the bars it STOPS WORKING. If I take the housing off, the switch still does not work; I have to pull the switch apart and reset it, then it starts working again. Until I re-attach the housing, then it stops.
I know the switch has its own ground (the gray wire), because I tested the little brown contact bar w/ my meter and see there's power - what I can't figure out is why it stops working when I close everything up. I thought maybe something was grounding against the handlebar )its damn tight inside the closed housing), but I figured that would have popped a fuse, wouldn't it? I also figured that perhaps I cracked the soldered point on one of the leads (it'd have to be the gray one, since if I popped one of the positive leads the OTHER side would keep working), but all looks well - the way the switch is designed the contact "buttons" are shielded behind the actual switch actuator, so I don't think anything's getting crammed into there. Plus the contacts look good (not cracked or broken), although the wires themselves are definitely all crammed around inside the housing - don't see what I can do about that, though, since nothing I can do will make MORE room inside the closed clamshell...
Anyone have any ideas (besides surrendering and hollering "uncle!", and cutting a notch in the housing to run the wires on the outside)? I'm at a loss...
--Matt
--Matt
