oh boy electrical
funkja
Active Member
1980 CB750C so the other night my roomie called me and said my brake light was on. odd because it was off and the key was with me.
the battery is a newer sealed(3 months) battery is dead so i hooked it up to charger and let it sit while i was at work. now my indicator lights come on but when i try to start it it just keeps clicking, its not engaging the starter at all. does this sound like a short somewhere? im at a loss as to why the brake light would be on while the bike is off.
any ideas on where to start? or a troubleshooting walkthrough?
appreciate the quick response, very cool i'll stick it back on the charger over lunch.
its a sealed battery, whats the typical charge time @ 2amps? and is it safe to crank it to 10amps on these batteries?
crazypj said:
Max charge rate is printed on sealed batteries.
Its not safe to go higher unless you like battery acid everywhere
Usually its 1/10th of amp hour rating for standard batteries, sealed batteries vary on max charge rate depending on type, (GRT, Gel, etc)
PJ
Talk about something that sticks with you. I made that mistake one time and one time only. Sounded like a canon went off in my face. There were 3 of us covered in battery acid and the top of the battery was blown off.
Also, you mentioned the solenoid clicks, not the starter. In another thread "should I pay" the bike mechanic told me my starter was clicking. Is he lying about this too?
well, thought all was done and good to go. i was wrong. I must have a short or something somewhere. charged up fully, took it for a ride, sittin @ the park with some friends and go to turn it on and nothing. not even clicking. so i get a runnin start and pop the clutch and get it home. i noticed when i got in the garage that after i turned it off all my lights were off like they should be. i went inside and came back out a minute later and my brake light is on. i toggled the key on/off to see what happened and it turned off. a minute later it was back on again.
help? anywhere ideas on how/where to start?
trying to eliminate what to check first. if my brake light(do not think its the running lights, guess i havent paid too much attention) is staying on after the bike is shut off(not in park; thats past 'on' not off) could it be the brake switch? i'm @ a complete loss as to where to start and taking the seat off to unplug the harness everytime i park kinda sucks lol. most shops around here are $100+ per hour on bikes older than '85.
