Oh Lord (CB500) - The Leaky Bitch (p. 31)
Re: Oh Lord (CB500) - Done! (?) (pg. 28)
Nice! man that amber lens catches the eye ;D i'd have to agree about some kind of inner gaurd to stop randoms getting flung into your plant, maybe a perspex number?
I have seem some guys fit a piece of clear plexiglass into the space between the rear tire and the engine area. Keeps the tire from slinging dirt and debris into your carbs but maintains that open frame look.
I'm really hoping I get to see this thing in person in the near future. We don't live that far apart. Got plans on going to Barber?
Today, two buddies came over and we set to getting this thing started up. We had some trouble, due to miss wired ignition system. I used a color wiring diagram that had the coil wired in a different order than the diagram in the Honda Service Manual.
Once it was all re-done, my budy bumped the starter just to make sure it was all hooked up right, and it surprised him by starting up immediately and running on the fuel left in the gas line.
Today is the first time I've heard this bike running, EVER! It still needs some tuning, but its almost there. I also need to figure out the cluth. The cluth handle isn't disengaging the cluth at all.
http://youtu.be/EyQN3JI4duw
Re: Oh Lord (CB500) - It Runs!!! (pg. 29)
how did the clutch plates look? sounds like the basket , jam nut is way to tight
Nope, your hearing hiss from bell-mouth and rattle from carbs out of sync/running on 2~3 at start up
Way to go! "Needs some tuning" is way better than "wont start at all".
Oh hell!
So today my buddy who is an experienced rider comes over to look over the bike, and take it on a short test ride in the neighborhood. We started out by working on the clutch adjustment so we could get the bike in gear without stalling it. We got that dialed in perfectly, and my friend rolls the bike down the driveway, puts his leather jacket and helmet on, and starts the bike.
Well damn. It was running like complete crap and getting worse as it sat there. It required more and more throttle to keep it running until it just wouldn't run at all. I open the gas cap to see how much fuel is in the bike, and I got a surprise.
The gas tank sealer was all blistered and pealing! I used the Caswell kit, and it dried very hard. I was actually quite impressed with the stuff. I let it cure for 26 hours before putting fuel in it, and it seemed good to go. I decided to take the tank off the bike, and in the process, splattered gasoline in my eye. Once the tank was off the bike, the bike ran awesome with the fuel that was left in the fuel lines. That is a great sign to me, as I don't think the stuff got into my carbs. But, the petcock is probably all gunked up now.
I called Caswell, and they were as befuddled as I was. At first, they said I had not properly mixed the stuff, and it must have never cured. I explained that I followed the directions to a "T" and the sealer had actually hardened to resemble solid plastic. The guy on the line said that if it hardened that hard, then I had mixed it correctly. The only thing he could opine was the problem is the possibility there is a fuel additive in the local gas that ate it up. They are being very helpful and sending out another kit.
So, I am going to have to get the old stuff out, and start the tank over. Its going to push me back a couple of weeks, but I guess I will push through.
Well damn!
Re: Oh Lord (CB500) - Oh hell! One step forward, and two steps back (pg. 30)
radiator repair shop should be able to get that all out... that sucks
I love the look of some of these fiberglass tanks out there but I am weary of using one because of all the problems I've seen people have. Wither that be from gas/ethanol eating the tank itself or the lining failing. I had a carbon/kevlar tank on my bike when I bought it but it was lined improperly and gas ate away at it and it sprang a leak.
I think I would give it seven days to cure completely, although a lot of 'overnight' chemicals don't develop full strength/resistance for about a month
There is alays a chance all the new 'cleaners' being added to gas are causing the problems?
I would think they would have to be compatible with newer vehicle plastic tanks though?
Glad to hear that Caswell is working with you on getting a new kit out. I just finished de-rusting my tank and was going to go with their kit. Seems they have the best track record with their kit, really happy to hear that they do provide support afterwards.
ahhh that sucks to hear about the tank mate, the vid is awesome though i love the pipes it would have a awesome tune cruising along. i wish you all the best with the tank situation though.
I would be inclined to give it more cure time than 26 hours, and make sure it was as warm as possible.
What would the ambient temperature have been during the curing?
Crazy
I've heard lots of good things about caswell!
I'm so fucking fustrated! I coated the inside of my tank with the Caswell tank sealer, and followed the directions to a "T". It cured for 26 hours, and was rock solid. I was initially impressed.
After a couple of hours with fuel in it, the sealer blistered and started pealing up. It looks like pealing skin after a bad sunburn. It clogged up the petcock, and shut down my bike.
Caswell sent out a new sealer kit, and told me to rinse the tank with acetone, being careful to not leave it in the tank for over 10 minutes or it would soften the fiberglass. I also put a bunch of woodscrews in the tank to help nock the crap loose.
Arghhhh I 'm so fustrated. It didn't do anything! I can't get the old liner out of the tank! I can only peel off off what I can reach wih my fingers.
I just got my motorcycle license and I want to ride! And I am afraid my expensive Benjie's tank may be RUINED.
Fuck, fuck, fuck!
Gas tank sealer not sealing my gastank but doing a good job of being crappy:
Re: Oh Lord (CB500) - So f--king fustrated!!! (top of pg.31)
take it to a radiator shop, they can clean it out, why would you coat the tank was it leaking???
I coated it because its fiberglass. I was told by the guys at Benjie's the tank comes uncoated and should be coated before use. Would a radiator shop be able to clean out a fiberglass tank?
