Oh Lord (CB500) - The Leaky Bitch (p. 31)
Re: Oh Lord (CB500) - 04/14/2012 Question about rear suspension bushings!!!!
Yes, its piece number 13. Its stuck up in there harder than hell. It will not budge once bit. PB Blaster, hammering, etc...
So, for how I managed to score the inside of it...
Please keep in mind I have no clue what I'm doing and I am learning as I am going on.
I thought I was removing piece number 10 from that diagram. I ran a hacksaw blade for a couple passes down the middle of the tube before I said to myself, "Wait a minute..." I pulled the bronze bushings out and after holding it up to the swingarm, and realized what I had done wrong.
So now there is a light score inside of it.
That won't be a problem, it doesn't move when fitted, gets clamped in frame.
It may be scrap anyway, if it's rusted bad enough that it won't come out.
You need to get a bar that slides through the new bushings, preferably reduced on the end to keep it centered.
Yamaha use through bolt grease feed similar to early Honda, never been impressed with it as the holes usually block
I prefer to drill swing arm pivot tube and fit grease nipple that is going to work (Honda did it on many mid 70's bikes)
uh oh. Now I'm nervous! I've got the rear end all assemble, and the swing arm goes up and down... But it might not be swiveling on the right part???? From that diagram, piece #13 seems locked to the swingarm, and the swingarm pivots around piece #11. I installed the OEM felt washer and plastic bearing into the swingarm, then installed the swingarm by greasing up part #11 and running it through the frame and swingarm. I think my swingarm is pivoting around #11. Is this right or wrong?
10, the bushings should be unmoving in the swing arm. They (and the arm) rotate around #13. I haven't rebuilt a swing arm without bronze bushings, which combine pieces 10, 15, and 11 into one bushing. So I can't comment on #11 rotating...
Are you using bronze bushings? I believe you leave out 15 and 11 if you are. Again, been a little while since I did it, so memory is fuzzy.
well shit, thats not good. thats not good at all. i gotta stay, now I'm stumped.
I'm a little stumped too. Are you using bronze bushings? And what all did you include in the reassembly? 15 & 11?
If you look at a bronze bushing, you can see that it's a combo of 10, 15, and 11...in one bushing. That's why you don't need the other pieces.
When you torque the swing arm bolt, the frame should compress against the collar (13), leaving the bushings free to rotate around t. I think.
Yep, it should.
The inner tube is about 0.010" longer than the swing arm tube/bushing flanges
I gotta thank you guys a lot. I know I keep saying I have no clue what I'm doing, but I REALLY don't know what I'm doing and I learning from the barest of scratch with this project.
I ordered the parts to redo the swing arm from Dime City. I'm going to get a length of 3/6" threaded bar from Home Depot and try to press the old parts out myself.
I have the bronze bushings, but never installed them because I couldn't get the inner collar out. Its frozen tight in the swingarm. I also had the OEM plastic bushings and felt on hand, new in the packages, and when I reassembled the swingarm, I used these. I did this because I was of course, clueless. You guys basically caught a big mistake for me that could have ended up being dangerous.
I just hope that the needle bearing and collar kit I ordered form Dime City comes with some instructions!
The stearing bearings are also proving to be a bitch! Lack of knowledge plus lack of instuctions proved to be fatal for the lower bearing pack and seal. I'm having to source another one of those so I can finish hanging the front end.
I'm a little disappointed; I was hoping to have this thing in roller form with the motor installed before I left to get married next week. Now I'm going to have to take apart all of the work I did yesterday with the rear end and basically redo it. Oh well, I guess thats how this stuff works!
I just hope I can get the old bearing and color out of the swingarm without bitching anythying up!!!
Crazy PJ and Ringo, thanks again for how helpful you guys have been! I wish you lived closer so I could buy yeah a cold beer!
I got a friend in Marrietta, I'll let you know if I'm going that direction any time ;D
His buddy works in Blue Riband Cycles
Ah nuts, I was in Atlanta... um... 4 years ago..?
I've got the swing arm parts and a new bearing pack for the neck ordered. It sucks going backwards, but I can't wait to get what I've done apart and reassembled working correctly. I really hope that the swingarm kit comes with some kind of instructions. I just don't know enough about how this stuff works to be able to intuitively put it all together. I'm still a little nervous about the top bearing race in the neck. It sticks up just a little out of the neck. I can't get it pounded in any lower. I hit it so hard using a 2x4 to spread the impact evenly that the 2x4 split into three pieces. I'll get a pic up later to get you guys' opinion on it.
On those swing arm needle bearings...they should come with instructions. BUT, I do believe they replace the bushings entirely, so it should be a pretty easy install...
Thanks Ringo. I'm looking forward to fooling with that stuff. I'm going to start pre-soaking the swingarm with PB Blaster now...
Here are the pics of my stearing neck:
with the bearings installed...
without the bearings...
Re: Oh Lord (CB500) - Stearing neck/bearings question pg 18 w/ pics. Help!!!!
sweet, got the replacementparts in! so, anybody mess with these All Balls Bearing with this kinda bike before? I really need to figure out if I've got the top race installed correctly! Thanks guys!
I want to say mine stuck up a little bit too. It doesn't seem to be a problem.
Check you didn't swap the inners.
I haven't seen a top with seal?
The inside diameters are different so it shouldn't be possible to get it wrong
The outer sticks up about 2~4mm
Hey guys. Just my luck, the swingarm kit's directions are in German!!!! My concern is that the bushings are not as long as the bronze bushings I have sitting on the shelf.
The kit:
31-6923-vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-honda-cb550-cb750-motorcycle-swing-arm-needle-bearing-kit-snbh0750_1.jpg
The bushings I also have on the shelf (thanks Ringo for the picture):
As for the stuff in the neck, I am 99% sure the stuff was installed on the right side, so I am just going to fool with what spacer to use on the bottom and run with it. Damn, I wish I wasn't working through the weekend because I want to put this thing up on two wheels before I leave for my wedding!
I'm going to guess that the bearings are a press-fit in. You can see if you can get them in, but I think the safe thing to do would be to have a shop press them in. Then it looks as simple as greasing the bearings, sliding the inner tube in and fitting the caps before installing in the fame.
