I pulled the stator cover because I have ignition problems an oil was coming out from where the flywheel are. That doesn't seem right because there must be oil around the electrics .
Or am I wrong
Correct, there is oil inside that cover and around the alternator. As long as you have a good gasket and don't forget the O rings around each of the three outer cover screws and you should be fine.
Ok super I was just surprised that it poured a bit out when I took It off. But it's not leaking
It just don't charge my battery so I thought that could be why.
