Could you provide a little further clarification???? What bike, what fittings? Check you can order Russell or Goodridge or any fittings Motovan or Parts Canada from Zdenos. Or if you want some automotive style fittings check with NAPA. Best I can do with such a general question...
Just looking to build a new set of lines for a 78 cb750 that I am building a new oil tank for. only restriction would be the adapting to the existing fittings coming out of the engine. Other than that, just looking around for a store that supplies general oil lines and fittings. I was also thinking NAPA or part source
You won't find fittings that will fit the CB750 in NAPA or most of the outlets I listed. Check out Ken at CycleX he sells new oil fitting for the motor and if you are building a new oil tank then you can select fitting that are the same as those from CycleX.
Look for any place that makes hydraulic hoses in your area. Here in Colorado Springs there is a business called Whisler Bearing. There are shops like this everywhere there are tractors. I just cut off my hoses and took my ends in and they put some nice steel braided lines on for $50.
