Oil, What does everybody Use?
Maritime
Over 10,000 Posts
Ok I did a search and came up with nothing. I am changing my clutch plates and springs so I need to change oil too. I want some insite into the best oil for the old air cooled bikes. I put Amsoil in when I put the motor in because the PO said he used syntehtic in it. I now have about 600 KM on it, the clutch is slipping like crazy and I don't think it is the oil, but????? I want some opinions. It is the motorcycle grade amsoil and they claim it doesn't effect clutches. I have heard Rotell T Diesel is good and I can get it in 4 litre jugs for 20.00 the amsoil will cost me 45 for 3 litres (bike takes 2.5 per change) it also uses about a litre between changes so I will likely need another litre so it will be 60 to do amsoil again. Would I be better off with Rotella Dino and change more often, or the Amsoil. Clymers says change the oil every 1000 Km's That is a lot of work when you do that every 2 weeks. I was hoping to get 2-3000 between changes on Synthetic. But with Rotella it would be the same cost, just more frequent changes. I want to protect my engine but I don't want to waste money on the syntethic if the dino oil is just as good.
How often do most of you change the oil and how much oil use is normal before you start looking for reason's it is disappearing? The bike runs strong and does not smoke at all, good comression etc, and no leaks as I park it in the same place all the time and there is no oil visible on the engine or ground, but the oil goes down about 1/4 litre every fill up or 150-160 KM's Is that normal?
Any and all opinions would be appreciated. Air cooled honda CB450T.
Thanks
amsoil is good stuff but expensive, i use it on my old vespa, and have not had the clutch slip yet and i have flogged the shit out of the vespa a couple of times showing off :D vespa wheelies :D
i use a full synthetic in my 450, it is mobil 1 racing full synthetic 4 stroke oil, it cost less than
$10 per quart
Thanks, I can get the Mobil 1 for 13 a litre at Walmart. I might go for that, how many miles do you go between changes?
Whatever oil you decide to use make sure it doesn't have the energy conserving additives in it. Those are what makes for potential problems with wet clutches...and also why most car oils are not recommended for bikes.
I used to use BelRay semi-synthetic in my bikes. Ran that in my FZR600R and GSXR1100 and also in the beginning of my kz650. Early last season I switched over to Rotella T after doing a lot of reading up on it. A gallon of Rotella costs just a bit more than a quart of the BelRay was running me, the primary reason I changed over (poor college student...couldn't afford the spendy stuff anymore at that point). I run about 1500 miles on the Rotella, keeping a close eye on it's color and whatnot, sometimes change at about 1000 miles if they were hard miles...Long story short, my kz and my GL both do really well on the Rotella, and I don't change it any more often than I did with the BelRay.
Thanks Anarki650, that is good info, I was hoping the Rotella was good for about that. 1500 miles is 2400 KM's and if I can get 2000 KM between changes that is one a month and I can justify the time and cost. I can also pick it up in the USA on my vacation for a lot less and save $$.
Cheers,
Maritime
I run Shell Rotella Diesel oil for it's zinc dithiophosphate (zddp) content which is critical for cam and rocker life - particularly on older tappet valvetrains. The zddp has been recently reduced in Rotella so I add some of this stuff to boost it:
TB-ZINC-PLUS
Lucas Engine Break-In Oil Additive is an exclusive blend of extreme pressure additives that protects camshaft, lifters and valve train during the engines break-in period. In fact, it is excellent for flat tappet camshafts during break-in or as an additive to prevent premature wear. Additive can be used with any motor oil, conventional or synthetic. Designed for race applications that require additional extreme pressure additives. Dyno testing shows a more efficient break-in when this additive is used, resulting in less engine run time prior to race day. One bottle can also be used with every oil change to increase the zinc content of your motor oil.
rotella is good, used it in my 500 ninja. i used valvoline motorcycle specific oil in my cb125 but that's just because it was fairly cheap and i only needed 1 quart.
I used valvoline full synthetic, no clutch slippage at all. Got tired of the nearly 7 dollars a quart, and now I'm back to regular old 20w50 valvoline racing dino oil for half that cost. By the way, what is that litre you refer to? ;D Course I'm lucky, I can get my oil filters at Auto Zone, too.
loudest143
I used the Amsoil for one oil change... No clutch slippage, but man that shit was high. I put Rotella in this past oil change and so far so good. I change my oil about every 2000 miles, dependant on the color and smell of the oil. My bike has two small leaks, so I know where it's going and add accordingly about 1/4 quart between oil changes, sometimes less. I use Lucas additive as well.
