OIL!
VonYinzer
Over 10,000 Posts
So what do you guys and gals run and in what? Its a heated topic depending on who you ask. Some guys swear by certain brands. Ive always been a castrol fan, but Im interested in what everyone has to say and why.
i run rotella in the cafe, not sure why, but it is cheap and i used it on all my CB's so i keep that in this one... all the rest of my bikes get amsoil 20W50 full synthetic or Lucas, i also do about 20oz of lucas oil treatment in all the bikes. best product i have found... EVER, even gets rid of the valve train noise in my harley
the trannys get severe gear by lucas or red line shock proof from amsoil, so smoooooth
my truck gets wallmart brand full synthetic, tested off the charts and blew my mind so i run that (cheap as hell and the truck take 6.6 qts) as well as a V8 engine treatment additive called restore. it is a fantastic product and worth the extra $10 each change.
Ya Restore is good stuff... Ive talked to guys who swear by MC specific oils for old bikes, and others who use standard oil, in the proper weight. Ive talked to guys who insist on full syn, and some who say it will destroy a motor. (well a clutch really) I used Castrol GTX in the 500 and the guy I sold it too (who owns a vintage Japanese bike shop) said thats all good. His son, who also is a tech there said he wouldnt ever run it in his bikes...
ya i will not run anything but full synthetic in my harley... nothing else
what you are talking about is why i run Rotella, it was highly recomended by several people to me when i built my firs and through the years it is the only oil that i have seen recomended over and over for vintage bikes... i do not run syntetic in anything older than an 85' no real reason just figure that if it is still running and go to this point good ol dino oil must be doing the trick!
Rotella doesn't have all the modern slick additives so your wet clutch will work. I tried a semi-syn oil in the Yamaha SR500 and it was a nightmare, so Rotella 15-40 in the old Yamahas and Castrol GTX 20-50 in the Airheads.
Terry
J'ville, Fl.
Any cheap oil will work on my bike but Motul 5100 is the best combination of performance and price.
I'll probably be running Shell 15W-40 in the GS850 once its on the road, at the moment its got Penrite 10W-50.
My stroker gets nothing but 'Valvoline 2-Stroke Race Oil' (blue bottle with a 'racing' bike on it), as its dirt cheap (Aussie $10/litre) and meets the JASO-FC criteria specified in my Aprilias manual. It keeps the bore clean and doesn't foul the plug much at all. I'd recommend it to anyone riding a two-stroke. You can run JASO-FD rated stuff like Castrol TTS (TSS?) or even the race stuff like Castrol A747 or R30, but I wouldn't bother unless you really do have the bike in quite a high state of tune or are racing the thing.
Cheers - boingk
Rotella in the bike. Pennzoil Diesel in the tractor and Walmart in the Cars. My dodge dakota had 150k before it was traded on cash for clunkers (body was shot because I bought it after it was totaled with 12k on it). Nissan Exterra has 120k and still going strong. My sons s10 had well over 200k before the fuel pump went out. I still go out and turn it over once in a while just to keep it moving. I also use marvels mystery oil at every change (3-4k) (but not in the bike) and sea foam at about every 9-12k.
Proper maintenance and regular oil changes per the manufacturers spec is more important than what oil you use. Of course, that's just an opinion, I guess.
loudest143
garden variety 10w40.
loudest143 - thats not an opinion, thats fact. Doesn't matter if you run a super-dooper oil if you neglect to change it when it needs to be changed. IMO, if going by milage, then equal to or more frequently than the manual recommends (especially if you give your bike/car 'hard use'). Otherwise every 12 months.
Cheers - boingk
loudest143
Probably true with the older type motors, but the newer stuff needs good oil. Especially for the top end.
Having said that I have a drag racing buddy who buys the cheapest supermarket oil for his drag bikes.....but he changes the oil for EVERY run down the strip ;)
Damn, posting error. Anyway the summary of it was that the advantages of modern oils generally lies in synthetic construction, which generally provides better engine protection, longer service life and better performance under extreme conditions. There is some fancy development around for molecular attraction (ie Castrol Magnatec) and other trick qualities, but synthetics in general really are a big leap ahead over mineral oils.
The GS Rescources has a useful article on oils which I reformatted as their page seems a bit out of whack: Oil Article
They also have a good article on oil additives, but this is debatable stuff in some bits. I've seen proven results with Slick 50 by way of leakdown tests and dyno runs - good enough to amaze a seasoned professional mechanic. I say if you leave oil in long enough for the stuff to cause harm as mentioned in the article then you won't have a vehicle thats running well anyway. Still, heres the article: Oil Additive Article
If you can't view the Oil Article link properly (like I couldn't) then PM me for a retouched version that is formatted properly for easy reading.
Cheers - boingk
semi synthetic on my dads 99 shadow, semi synthetic on my 350. clutch slips on my dads shadow with full synthetic, and on my 350 i dont even want to try it. would probably leak everywhere.
oil doesnt matter much. get the best stuff in the grade the bikes manufacturer reccomends and your good. change at the first looks of it getting dirty and your fine. oil doesnt wear out. it gets dirty. oil doesnt get old; its already millions of years old for christs sakes ;)
and there really isnt too much of a difference between synthetic and non synthetic. the bikes ran just fine for 30 something years on dino-oil, your not going to gain much from synthetic. i mean, if it means your gaining a horsepower, or maybe even a half a horse, i would spend money on THAT oil. but its just not the case.
lube is lube. and ive never had a problem getting the natural stuff to work ;)
i dont think ive read so many poorly thought over statements in my life. 'nuff said.
I run Castrol 20W-50 in the BMW. I run Hondalube 10W-30 in all of the other bikes. I like the idea of using a "good" name brand oil. Whether it makes a difference or not, it makes me feel better! Neither of the oils I use are synthetic. The BMW tech suggested not running synthetic in the Beemer until the engine was fully broken in (60K). It's an '02 with only 8K on the meter. I'm probably not gonna get there any time soon.
yeah i agree... i wasnt really thinking about what i wrote whatsoever. my mind kept going back and forth to the ridiculous amount of homework i have to do by tomorrow ;D
I found a forum a few years back that I spent some time on. It was a Petroleum Form http://forum.cippe.net/ (I think this is it but I'm not 100%). anyhow it had a group of chemist and petroleum engineers that actually had testing labs set up at their homes. They were having conversation on this same subject. It was on a different level of course and so much so I had a hard time understanding half of what they were talking about. They were actually doing their own testing and reporting for personal use. I figured what better place to learn about oil than from a group of chemist and engineers doing their own testing.
I can't remember much but I do remember that for the most part they all agreed on each others findings. One thing that stood out at the time was that most of these guys change their oil before it was recomended. Some were using Amsoil and i remember Mobile 1 as being a big hit. they also really liked Seafoam in both crankcase oil and in the gas tank.
I wish i could remember more. I had it saved but the computer it was on crashed. I'm going to try hard to find it again.
On another note if you are interested in the opinions of oil engineers on peak oil and climate change, the above forum has some pretty interesting posts.
I'm not surprised. In the GS site article it mentions that AMSOIL can formulate their 10W-30 and 15W-40 with no viscosity index improvers but uses some in the 10W-40 and 5W-30. Mobil 1 uses no viscosity improvers in their 5W-30 and most probably their 10W-30. This is a big deal because viscosity index improvers (ie polymers) generally break down over time and use to cause deposits which can contribute to rings sticking and other problems. The less of these polymers in an oil the better.
AMSOIL also seems to have a very low ash content. This again means lower formation of deposits and, specifically, longer valve life. Couple this with its slightly above average viscosity index (better protection), relatively high flash point (low oil consumption & deposit formation) and low pour point (good cold weather performance) it seems like a darn good oil all around.
Hmmm.... ;)
- boingk
