Old Carb intake boots
surfish95747
Active Member
Okay guys, I need your advice! I rebuilt the carbs on my 1980 CB750K and while looking at the carb intake boots, they are extremely stiff, brittle and cracked around the edge connecting to the engine. Do I replace them? I want to use Honda Genuine parts, so that means I'll spend somewhere around $90. Is it worth it to replace them at this point or are they good to go for a while longer? Thanks!
P.s. the air box boots are pretty mangled too, cracked and pieces falling off. I pretty much know these need replacing. Thanks!
It's one thing to recondition a stiff boot, however if they are cracking I would absolutely replace them. It's one of the leading causes of air leaks, and in this situation you will never be able to tune your bike to proper spec. It's a minimal cost for the lack of problems it can cause in the future.
i have a 1980 and just switched to dual mikuni carbs so my air box is in good shape if you
want the boots or the whole box i also put on new honda isolators due to cracks in the old ones
PM me how much you want for the air box boots. I'll definitely be getting new intake boots. Thanks guys!
