Overcoming Modern fork swap issues!
FunJimmy
The modern fork swap craze has become an almost epidemic amongst the cafe crowd (self included) but several are experiencing fitment issues. I've read in several build threads lately (550 & 750) of wheel to header clearance issues as well as triple offset concerns. Modern fork swaps certainly aren't new and have been a very successful upgrade, but why are some having problems while others don't? Is the problem exacerbated by inverted forks vs conventional forks?
Modern Sportbikes have considerably steeper head angles which require short forks with minimal offset to get the geometry in the sweet spot. Classic old school bikes have relaxed head angles with more offset = longer forks, but does this EVER get factored in when selecting a donor front end?
Correct (optimized) chassis geometry is essential to a well handling and safe motorcycle. There are several good resources on the topic scattered around the internet. Do a search, read and digest this information before selecting an eBay special front end.
Here's a good start that I found.
Art & Science: Fun With Geometry
How your bike handles depends considerably on front-end geometry. Here's how to change it.
From the June, 2010 issue of Sport Rider
By Andrew Trevitt
Illustrators: Andrew Trevitt
Rake and trail are terms often used when discussing sportbike handling.
Manufacturers sometimes highly tout these numbers in their brochures, and we often refer to them in testing.
Trail especially affects how a bike feels, and can determine its stability, steering quickness, and in general, a large portion of the bike's handling characteristics.
Rake is defined as the angle of the steering head with respect to a line drawn perpendicular to the ground.
A smaller angle, or less rake, is sometimes referred to as being steeper, and production sportbikes are currently in the neighborhood of 23 degrees of rake.
Trail is the horizontal measurement from the front axle to the point at which a line drawn through the steering head intersects the ground.
Current sportbikes have 90-95mm of trail.
While the two dimensions are interrelated, trail is the number that mostly changes the steering feel of a motorcycle.
Trail gives a motorcycle stability because of the self-centering effect caused by the front wheel being behind (or trailing) the steering axis.
Too little trail, and this self-centering effect is decreased to the point of instability.
Too much trail, and the effect is so great that steering becomes heavy.
There is a lot more to trail than this (and for more detail, you can refer to the resources listed here), but these are the basics for the purposes of this discussion.
At first glance, most sportbikes appear to have a set rake and trail that cannot be changed, but that is not necessarily the case.
Given a motorcycle's basic dimensions, we can calculate trail as follows.
(equation 1)
Trail=RSinø-0/cosø
R=tire radius
0=triple-clamp offset
ø=rake
As an example, a bike with a front tire having a circumference of 1890mm, a 23-degree rake and 27mm of offset will have 98.5mm of trail.
Note that in the range of variables we are dealing with, using a tire with a smaller radius, increasing offset or decreasing rake can decrease trail.
On most stock sportbikes, you cannot change two of the three variables (tire diameter and offset) without resorting to modifications, but the third variable, rake, we can change slightly by raising or lowering the fork tubes in the triple clamps.
An expert-level roadracer can notice a change in the order of 1mm in trail, and working equation 1 backward, we can calculate the change in rake required as just less than 0.2 degrees.
Using an approximation based on the arc length from the rear axle to the steering head, we can further calculate that a fork-height change of just 4mm is enough to effect this angle change.
Many riders refer to fork height or rear-ride height change as "putting more (or less) weight on the front end," but we can calculate the change in weight bias brought about by this 4mm change.
A typical sportbike and rider combination weighing 600 pounds has approximately a 50/50 weight bias, with its center of gravity (CG) at a height 1_2 of its 1400mm wheelbase (figure 3). Front-end weight is calculated as:
Wf=Wt(L-x)/L
Wf=front-end weight
Wt=total weight
x=distance from front axle to CG
L=wheelbase
In this case, the bike's weight is evenly distributed, with 300 pounds on each wheel.
Raising the fork tubes in the triple clamp and changing rake by 0.2 degrees will move the CG forward by approximately 3.5mm (you can use trigonometry to calculate this), resulting in a front-end weight of 301.5 pounds.
This is practically insignificant compared to the change in trail resulting from the adjustment-you would have far more of an effect on weight bias by simply moving your body a little bit forward.
Raising or lowering the front end of your bike changes much more than just rake and trail, however.
It also changes the angle of the swingarm, which can play a big part in handling, especially on more powerful bikes.
We will cover more rear-end geometry in a later issue, but you should know that adjustments in trail are by far the most apparent change a rider will feel when raising/lowering the bike's front end.
Tire diameter is one of the other variables affecting geometry, and we can calculate the change in trail resulting in a switch between two brands of tires.
In our last tire test ("DOT Race Tire Test," Feb. '03), the tallest front tire was the Michelin Pilot Race 2, at 1910mm in circumference.
The smallest tire was the Metzeler Rennsport/Pirelli Supercorsa, at 1878mm.
We always measure tire circumference and change ride heights to make the overall chassis attitude (and rake) the same (see Ask the Geek, Feb. '02), and in this case, the fork tube height would need to be changed by 5mm just to level the chassis.
Even taking that into account, however, the change in trail due only to the change in tire size is 2mm.
Add in the different tire's profile (that changes trail at various lean angles), and you can see why adjusting only to keep the bike's attitude the same when changing tire brands is sometimes not enough.
The last way we can adjust trail is by changing the triple-clamp offset, and you will see that racebikes often have this adjustment.
In this case, a 1mm change makes approximately the same change in trail (but opposite-more offset gives less trail, and vice versa) with very little effect on ride height and rake angle.
My simple, non-scientific survey suggests that Suzuki GSXR forks are the hands down favorite. Popularity made even more so thanks to vendors that produce hubs specifically for this combination and the sheer volume of forks on eBay which drives purchase prices to near record lows, but not all GSXR front ends are the same.
Triple offset varies from 28mm to 32mm and fork length differs depending on model and year.
There's a lot of good information at: http://www.svrider.com/forum/showthread.php?p=2163049
There is no reason to use a 17" front wheel to get the correct fitment if you select appropriately. Before settling on a specific frontend, ask the seller a few questions like fork (extended) length and triple offset if possible.
Fork extenders are also available if a longer overall length is required to get it right and getting it right makes all the difference.
Here is a fork length comparison you might find interesting and helpful.
From left to right: 00 R1 - 05 R1 - 06/07 CBR1000RR - 04/05 CBR1000RR
Just because you've decided to use a GSXR, CBR of any other front fork doesn't mean you have to use the accompanying triple trees. Consider mixing triples to get the best results for your specific project. Ducati standard offset is 36mm as an example of one option that might work with correctly sized forks. Search the clip-on listings to get an idea of the various bikes that use a similar sized fork and ask the sellers to measure tube diameters at the top and bottom triple clamp.
These extra efforts will be rewarded with a (safe) performance upgrade that will surprise sportbike riders everywhere.
good info, also, consider the wheelbase of modern bikes vs vintage, that has a big effect on handling as well, it's actually a pretty involved affair to get an old bike to handle really well using newer equipment, most never even attempt to get things to work well
Jim, I haven't seen you around on the board yet but this is a great first post for me to see. People need to read this stuff. Welcome Mr. Fun.
Bookmarked. This would have saved me a lot of time six months ago - thanks much.
Hi Clem,
Thanks for that. There are so many motorcycle forums I visit, I don't seem to participate as much as I'd like. There are some 262 other posts but mostly in the project build blog.
Check it out. Link in signature at bottom of this message.
Hope to chat again
Jimmy
Great info. I wish I had more measurements of triples (fork diameters as well as fork center width and offset). This stuff is all very difficult to measure, especially when changes are done in concert with wheel and tires.
Awesome post! Anybody have triple tree dimensions for the 89-90 Suzuki GSX-R1100? The conventional ones, not USD.
Edit:
Or does anybody have dimensions for the 88-97 gsx600 or 89-96 gsx750 triple trees?
Good information! I've reverse engineered 03 gsxr forks and my cb750k7 frame. I can try to validate these equations in my cad mockup and design this relationship correctly thanks! I started a thread on my digital project under project cafes.
Hi there, a Newbee here, I've loved bikes since I was a kid but had been more involved working and restoring cars in the past which takes waaayyy to much time, (welding in panels, fabricating panels etc.) I've now decided to take on a Cafe Racer project and as a Newbee thought a Honda CB project would be a great starting point. I like the idea of the GSXR front end conversion and have looked through many threads on this and appreciate it's been covered many times although I can't find an answer to the following, why not just use a Narrow Glide front wheel for the conversion instead of separate Hub rims etc? Is it just down to personal preference and look? There's a place in the UK that sells complete wheels with 19 inch 2.5 dimension which look pretty good value.
Cheers
Thanks for posting all that information, nice to see someone else helping instead of just saying, 'do this' not my fault if you get hurt' 8)
The cheapest narrow glide wheel you'll find is $50. The ones with the 1" internal axle diameter are much more difficult to find. You also have to figure out rotors and calipers and brackets. The real tricky bit is the spacers. I have been unable to find dimensions anywhere, and you really can't fuck those up if you want the bike to near a ton without pitching you. In the end, it's easier and possibly cheaper to buy the custom hub and just use parts from a complete GSXR front-end.
