Paint question
mccarleyholmes
Active Member
I am planning on professionally painting my tank and single seat, just looking for advice on what brand and type of primmer paint, and clear. I will not be rattle canning it, I want something that will withstand gas drips and is UV resistant. Any one know automotive refinishing, that can give me some pointers. I am planning a two tone job with metal flake, or gold leafing (what clear is used for this?), I have access to a proper spray booth, great compressors and decent spray guns.
Let me know your thoughts.
Thx Mike
had good luck with dupont, did a tank and seat and the clear ended up looking like glass when I was done with the rubbing
house of kolor sux, ppg is good but their paint doesnt always match too well when using a code to mix the paint, dupont is my favorite by far.
Can anyone buy Imron? i used to work in a custom bicycle frame shop that used it but I couldn't buy it myself. Imron supposedly is only sold to professional shops, it's quite toxic.
HOK only sucks if you are not used to super thin paints. Think nitrocellulose lacquer. Very touchy, very finicky. It runs, it lifts previous coats, it orange peels like a mother... But if you take your time and follow the destructions that come with it, you can't beat it for crazy paintwork. Think real East LA lowrider panel fade lace fog with underlayed designs crazy.
Imron? Why bother? Deltron is just as strong and a hell of a lot easier to get. Either one will kill you double quick if you spray without gear, they are both isocyanate urethanes. If they don't kill you, they will kill your little buddy, vasoconstrictors.
VonYinzer said:
So... HOK sucks? Whys that? :-\
the only thing house of kolor is good for is for their bright colors and candys for achieving crazy color combos. their "paint" coats like shit, more often than anything you have to do like 10 coats of the shit (which makes for a less than desirable durable finish), it takes forever to dry, and if you used bondo anywhere it WILL bleed. i stay away from house of kolor if its possible.
Thank you for all your feedback. I Painted my wifes vespa using PPG, and it looked good for a year or so. So i have experience spraying single color paint jobs. I plan on attempting a two tone on my single seat and tank. I would love to do a heavy flake with a solid british race green. Here is my mock up, before i strip it.
Question, after prepping , priming and sanding should i paint entire tank with metal flake, then mask and repaint solid green over entire tank? Or green then metal flake? I have also been researching gold leafing, and was wondering if the same clear can be used when introducing gold leaf and 1shot adhesive? also can you recommend a good degreaser to use in-between coats? any other recommendations or pointers you can give to make this a successful, clean refinish.
Thanks you guys are awesome.
Mike
paint the entire tank green then the gold color.....if you were to do it the other way you wouldnt get as sharp corners and itd be way more challenging to tape.
oo one more thing.....since this is a two tone paint job be sure to use base coat clear coat....single stage is not a good idea.
thanks for your quick response...
this is my game plan
Prep, bondo, sand 300-400 grt
Prime
prep and sand 400- 600 grit?
Base coat
Clear coat
wouldnt I fine sand here as well 700 grit? to get 2nd coat to stick?
2nd coat (metal flake)
Hand pinstripe, or thin vinyl sticker.
2-3 coats of clear?
