Painting over chrome
Chrome is not easy to paint over. Paint doesn't bite into it, and ends up flaking off. You need to rough it up pretty good with a dual action sander with a diamond grit paper or emery, then prime it. Even then it's iffy.
your best bet is to take them to a sandblasting outfit. or if ya know sombody with an industrial size baster. most little home units wont really cut it. somtimes chrome is reallllllly tuff. i soaked a chrome rear fender in muratic acid for a couple hours and all it did was cleann off all the rust spots...went to a grinder with a sanding pad. 80 grit maybe....smoothed it down a bit with 120 grit on my random orbital. then used self etching primer. several coats with plenty of sanding. a high build/filler primer prob woulda been easier but it turned out well anyhoo.
what part are ya doing anyway....if its rims, i feel for ya...
Most chrome platers will can remove chrome via reverse electroplating for a reasonable fee. With the chrome removed, you can proceed with prep, prime. paint, clear, polish etc as usual.
Good rough sanding followed by a good clean and prep will get you started, The appliance epoxy spray or bed liner paint tend to hold up pretty well, regular primer and spray paint will only give you an iffy paint job. Good luck!
Thanks everyone. It's the front fender I'm thinking about painting. It doesn't fit well with the paint scheme and lack of any other chrome on the bike. I might just take it off, but I'll give it a shot at sanding/cleaning/priming first.
