PAMCO install help
Bolts189
This'll be my first time installing a PAMCO unit and I want to make sure I've got everything down. I'm going to be installing a PMA at the same time, andI remember reading somewhere that you should have the PAMCO hooked up to a separate battery so you don't short the PMA due to bad wiring. If anyone has any tips or has done both of these upgrades at the same time can offer any advice. Should I do the PMA first or the PAMCO? Should I set the timing after installing the PAMCO or once everything is done? Sorry about the long wall of text, but any help will be much appreciated. Thanks!
