Hi I've bought a head light with side light that goes around the lamp .my question is can you have this working with the m unit .I have green =earth white =low beam blue =main beam brown =side light .
I would bypass the m-unit for this feature. I assume your ignition switch has a setting for the parking light? If that's correct, just run power from the parking light ignition switch wire directly to the brown wire on the headlight.
