Parting out 1973 Honda CB350F
carnivorous chicken
Over 1,000 Posts
Complete engine (parts or rebuild -- low compression as it is now) -- $200
Titled frame -- $200
R side cover, red, in excellent shape: $50
Ignition key switch, seat lock, and steering lock, all the same key, with two original Honda keys: $60
It's missing a few things but most of everything else is there, ask if you are looking for something specific...
A few photos of stuff...
Front turn signals, nice shape, mild surface rust that will clean up but no real dings or dents or rash. $35
Flake Matador Red headlight mount / fork ears. Complete set, including rubber mounts and chrome caps. Very nice shape, a couple blemishes, one for ear has mild crease, one lower has a small bend that's not visible when they're mounted. $75
Original saddle. Foam feels like it's in nice shape, not saggy. Cover is intact and will shine up. Pan is solid. Bolts for strap could use some attention, and the trim is showing it's age. $100
Right side cover, Flake Matador Red. In excellent shape, one small chip, and a little of the white has come off the emblem. No cracks. $60
More photos...
Air box assembly, in great shape, rubber mounts still very pliable, original clamps. A few scratches, but very nice, $60
kickstart lever. Nice shape, a few small scuffs. $35
Complete headlight assembly. Bucket is solid with no cracks or chips, small spot where paint has rubbed off (maybe due to cable) and looks like maybe a little brake fluid spilled on it. Ring is in fantastic shape -- no dings or dents, and no rust. Comes with functioning headlight, both high and low work (tested), headlight mounting wires, spacers and hardware. $100
Complete front brake assembly, including brake lever, master cylinder, lines, connector with brake light switch, metal line at the end, caliper and pivot, and dust shield. Will need a rebuild, got a little corrosion. Lines still very pliable. $120
chucklump said:
Right hand control?
Hey Chucklump -- I've got it, but I am considering selling the bars complete with both controls. I've found people are after stock bars with the wiring threaded through them. I will let you know if I decide otherwise...
Can do -- but unfortunately the engine is still in the frame, and I am leaving tomorrow for a couple weeks... I'm guessing shipping via Greyhound would be $150 or so?
Hey all, been out of town for a month, bumping this, tons of stuff left. Wheels. Airbox. Tool tray and lid. Shocks. Seat. Engine. Kickstands. Brake. Nice rear fender. Nice front fender (with a ding in the back). Etc. PM me with your email and I will send photos...
Still have tons of stuff. Tore into the engine today.
Camshaft, in excellent shape, low miles bike, no damage or wear on lobes, with the sprocket: $25
Rocker box, all rockers included, no wear or damage: $30
Cylinder head with valves and springs and carb intakes. Could use some cleaning. No broken fins. All nuts included, missing one copper washer. $50
Cylinders/jugs/barrels, in nice shape, smooth looking bores, no broken fins: $50
Starter motor: tested, works fine, with bolts: $20
points plate with nice set of points and condensers, and spark advance: $25
Feel free to PM for photos or with questions, or if you're looking for something else. All prices do no include shipping!
More parts pulled and cleaned up today:
Nice, straight forks, couple of minor, minor scratches on the lowers, tubes are straight and have just a little rust where they meet the clamp, but not in the travel area. Chrome lower covers in very nice shape. $50
Kickstand, straight, $10
Complete air filter housing, electronics panel, and battery case with rubber strap, plastic lid for the air filter. $20
Chrome horn and key switch housing, nice shape, $10
Brake lever, nice shape, a couple tiny scratches, $12
Chain guard, straight, nice paint, small rub marks, still has exhaust sticker: $15
As usual, happy to send photos, shoot me your email in a PM.
