Well you probably already know about your new octane requirement; premium fuel or nothing. Race fuel (110+ octane) would be even better. At compression levels at or over 11:1 you're going to need high octane to help prevent detonation. I'd also have a machinist look over the squish area created by your pistons. You may need to deck the head a bit in order to get a good squish band. If so, you're already pretty high on compression and so you may want to slightly increase the combustion chamber area to account for the metal less between the head and the jugs. If so, you're going to be looking at retiming the cam, too. Decreased distance between the crank and the cam will retard your timing and so you'll want to slot the cam gear and adjust for this.
While you're there, you may as well get the head CCed to make sure both combustion chambers are equal in size. A port and polish, 3-angle grind, and lapping is usually considered at this point as well. Don't neglect your valve guides if these are still in stock form. Bronze replacements are the norm, though I'm afraid I don't have much more info than that. Hopefully someone else can chime in as to why.
67.5mm bore should put your displacement at 362cc, right? You mention the VRAA rules, and so I'm assuming this is a race-only bike? If so, VM32 should be fine. If the bike is going to spend some time on the street as well, consider the VM30s, instead. The throttle response will be better.
Also... take a look at
RD Valve Springs. They have a very good product and I find their prices to be quite reasonable. I'm running their aluminum set right now and they are noticeably lighter and stronger than stock. Not sure if they do aluminum for the 350, but I know they have Titanium (which is both lighter and more expensive).
Finally, if you're interested in buy the VM32s new, I can get you a set on the cheap (about $200 for the pair). Also, I'm in the process of importing some stainless steel valves for my 360 and I'm going to order a few extras. I'll probably be going +1mm over on those. Lemme know if you'd be interested (350 and 360 use the same valves). Prices haven't been finalized, I'm guessing that around $150 will cover it. The VM32s I could have for you in a little over a week, though I have not yet have an ETA on the valves (hopefully within the month, but nothing certain yet).
