"Patina" The 1973 CB175 Cafe Racer
xb33bsa said:
try to get spark with no cap or sparkplug ? just gapping the wire to a ground?
is coil grounded direclty to frame?
I didn't know you could do that? Just hold the wire about .030 from a engine stud bolt?
I've tried thT with the plug but not bare wire
The coil needs a positive (switch) and ei connection. These coils don't ground through body.
But do check all your grounds. I had a problem because of the powder coat. I needed to bond motor to chassis- chassis - headlight bucket- headlight bucket - back into harness.
Re: "Patina" The 1973 CB175 Cafe Racer
Yeah I think I'm pretty square there. I'm not drawing hardly anything from the battery if I test the ground strap to the negative terminal.
Just grab that wire and kick it. If you feel something your good.
Yeah but what about past that ground strap. Poke your negative and probe around your engine and other places that need grounding
Will do.
1sttimer said:
I only found my problem when I took out the original regulator rectifier. The original grounded to the frame and was providing ground back into harness.
No continuity?
Also tried both bare wires in the holes without metal connectors. No continuity. If I take the caps off I get continuity through just the wire.
In all honesty I don't know what other combinations there are to do. At least I'll feel prepared coming into that conversation...
I will check ours when we get home with a voltage ohm meter.
I once had a cheap meter. Battery was dying in it. But you are trying to get spark out of the wires? In between all these steps right?
I use this guy
When looking at the coil. Put the positive on the left side. That's what they say is positive. And also once again make sure your getting 12v+ to coil with key on/off (switch in your case)
I'm honestly not sure where to begin to get a spark out of just the wire without the resistor cap to connect the spark plug. I mean I could wrap the wire around the head of the cap I suppose but I have no idea what that thing is you pictured :/
What setting are you using for your continuity on the voltage ohm meter?
this is what we are getting with non resistor caps through the plug wires.
