Sonreir said:Just loosen the nut and adjust with a set of needle nose pliers. It shouldn't require much force once the nut is loosened.
yes to answer your question but we use an 8mm to loosen the tappet but a pair of needle nose to adjust the tappet1sttimer said:Is there a special tool for this square head nut or just use a crescent wrench?
Sonreir said:Also... sort of on topic... but you can actually calculate the expansion rate of the tappet.
Steel expands at a rate of 0.0000067 inches per degree per inch.
So assuming the tappet is .25" long, your starting temp is 72°F and ending temp is 300°F, you can follow the math:
300 - 72 = 228 (Delta T)
228 * 0.0000067 * .25 = ~0.0004"
Or in otherwords: Next to no expansion at all.
they make a tool for it it can be done with needle nose but the correct fitting wrench/tool makes it much easier1sttimer said:Awesome!! Thank you sir.
thanks cxman that watch winding tool is the ticket 8 bucks is better than 40 buckscxman said:yes there is a proper honda tools set for adjusting the tappets you might even know someone who has it
and i found a set
http://www.ebay.com/itm/Honda-Z50-CT70-SL70-ATC70-XR75-CT110-CB350F-Tappet-Tool-Spanner-and-Adjuster-/121557135787?pt=AU_Motorcycle_Parts_Accessories&hash=item1c4d5eb1ab
you can also just buy a watch winding key in the right size for about 7 bucks i think its a number 8 key but double check
http://www.ebay.com/itm/Hermle-Clock-Winding-Key-Crank-Size-8-NEW-4-1-mm-Chrome-Howard-Miller-Ridgeway-/271020078359?pt=LH_DefaultDomain_0&hash=item3f1a0e3517
and i found a set
teazer said:That's fine. Could be higher but it isn't, so let's get it ready for spring which will be here before you know it.
Texasstar said:Awesome! Are you going to warm it up and check it?
This is what we use on stock tappets (valve adjusting screws).
http://www.ebay.com/itm/2218-6-PC-HONDA-YAMAHA-SUZUKI-MOTORCYCLES-VALVE-TAPPET-ADJUSTING-TOOL-KIT-/191504295233
Ours are hollow and broached for a hex key, but that's a secret ;-)
you need to get the engine running and put it through a heat cycle before doing the leak testsTexasstar said:The Amal carbs on our Bultacos leak like none other and we found a boot on one carb over the carb for the first time. We are learning about pulling a vacuum on the two stroke to check for leaks. Do you have the black spacer between your carbs and your head?
