You didn't have any issues with truing the wheels with the coated nipples did you? Did you see any wear marks on them from turning them in the rim holes? They did come out nice.
Your comments on lacing the wheels reminds me of the first time I did a brake job on my car (44years ago), 1st wheel took about an hour, the second one took about 10 minutes. Your lacing looks like a standard 2x4 (2 cross, every spoke crosses 2 others), every 2nd hole on the hub goes in every 4th hole in the rim. Start at the valve stem hole and lace all the left side clock wise, then the left side counter clock, then flip the wheel and do the same. It helps to have a diagram in front of you, easily downloaded from the interweb. But I agree it is a time consuming task.
