1sttimer said:
Has anyone ever put a piece of cylindrical foam down the stack as filtration?
that would also cause even greater loss of HP than the screens you have in there now ::)
if you are going to have a filter or screen it must have a large enough surface area to breathe freely or you loose
that is the issue with the tiny fine screens inside the stack too little area
This is all really good information, guys. Thank you for teaching and not yelling at me :)
One more question I have is regarding intake radius on the velocity stack. From what I have read, the flare on the end of the velocity stack is to essentially smooth the entering air to utilize the stack most efficiently. If I were to have no flare at all (imagine just a straight tube coming off the carb), is there a dramatic effect on power? I assume the flow would be restricted, not utilizing the entire ID of the stack and causing some magnitude of turbulence but is it noticeable?
And another question while I'm thinking about it...I read a lot about people having high idle problems due to leaks around the intake. My velocity stacks, along with the majority of the ones I've seen that bolt straight to the carb, are simply attached using three set screws. It seems like there would be a small circumferential gap between the stack mounting flange and the rim of the carb throat. It may be small (on the order of .010") but it seems like I am missing a "sealing" component that I would not have to worry about with a stock or "booted" connection to the carb.
this shape will give 2% more and this (blue) is what we are running and they 30 bucks ea.
We closed the gap with yellow Teflon tape used for gas connection.
The key is to think about the velocity stack as a component of the perfect intake shape for thAt pick up a copy of David ViZards book it covers it a-z
Also think of what happens when your toilet is clogged you will get no velocity out of your shit till you take care of the clog. Now our velocity stack made 1/2 hp difference on the Dyno after we gas flowed our exhaust port. Most of what you are told initially to build a cafe racer is backwards. The key is Suck Squeeze Bang Blow...if your suck isn't sucking then you suck.
Pat's first pic of the stacks is a great shape. As close to 180° bend around the bellmouth as possible.
Straight stacks with no bend will not work well at all. They'll be hard to fit any filters to, too.
Finally, you don't need to worry about air leaks before the carbs, it's after the carbs that are the issue. Between carbs and head, specifically.
Thanks guys, again lots of good info. Unfortunately, the dang frame rail is right in the way and my options for decently short stacks are kinda shot. Texasstar, if I'm correct you switched to Mikuni's and the geometry is a bit different, correct?
I hope that I can fit the Steel Dragon stacks on with enough room for an external screen. I should be able to try tomorrow.
I think right now, my main concern is longevity and that's where I need to put my focus. I believe a pod or UNI filter would serve me well here.
Moving forward, if I can't get the long stacks to work out for me, I also have a 3" long set that currently interferes with the frame currently. I am thinking I could cut the flange off and use it as an extension to get beyond the bulky frame rail and mount some filters.
I think I have a lot of options here, but we shall see....google images helps out a lot to see what other people have done to get around the frame.
Maybe something like this?
http://www.hybrid-racing.com/store/hybrid-racing-velocity-stack-and-filter.html
Grab this quick and save a copy. I found it on a Vizard site or article a while ago.
As you can see, the taper helps where a parallel section doesn't really do a lot, but the key is entry to the stack. The percentages are flow and not necessarily power but smoother flow usually means more power.
In the case of length, that potentially changes the revs at which peak occurs. Longer theoretically peaks at lower revs than short but reality is less simple than that. We found longer (CB750) stacks work better overall that short (CB500) stacks.
Parallel tubes on short inlets work better than no stack with a short inlet but longer inlet manifolds and long stacks made the most power under the curve on our motor. YMMV.
thanks Teazer so 11 is the smoothest?
You, my friend are the smoothest (operator). I'd just say that it flows most air and therefore is what I want on my next two stroke race bike - check out what Paul Gast offers for Lectron 44mm carbs and you can see where he's coming from.
Honda basically are #10 shape which is less than 1% away from the best. Not bad for a stock OEM part.
Got is saved! Are these percentages of flow losses? Certainly not power losses...?
They are %age changes in FLOW compared to a bare carb, so #1 is a decrease in flow and #11 is a significant improvement.
I guess my question should have been about units. This is speaking volumetrically?
are you always on the cusp?http://www.dragbike.com/dbnews/templates/fast1320_z11.aspx?articleid=5574&zoneid=12
I hope so ;-) Not really but I have been reading and absorbing tuning books, magazines and software for years and I try to keep learning. It's the old story - the more I learn, the more I realize that I don't know.
It's really just a process of searching for information and looking at things and looking for parts that are different or changed and asking WHY and putting pieces of disparate information together to create a more complete answer.
