Here's a scan I made of the same gasket, from what I think is a different manufacturer. It has the same step up. I have also experienced a small leak from this area before, though I later found it was because oil escaping from a damaged clutch pushrod seal pooled on the shelf beneath the front sprocket and dripped out in that area. You could always put some hylomar (or another brand (yamabond, hondabond, etc.) on the sprocket cover right there.
Re: "Patina" The 1973 CB175 Cafe Racer
Perfect. Thanks man I just wanted someone to verify that. It's strange.
So for your clutch pushrods seal, you're referring to the one actually on the crankcase right where the rod runs through the case?
I'm dying for the fedex man to drop off my loctite 518 so I can get this thing back on the road.
Yes. After being frustrated with following my bike around with an oil pan everywhere I finally did some detective work and found I had a small leak coming from there. New ~$10 seal fixed it right up.
It is frustrating! It looks like I'm try at the seal (they are new anyway). It's just pooling around the bolt between the surfaces. Hopefully the Loctite knocks it out.
Is there any opposition to using motor oil as foam air filter oil? UNI's website says to not do that because it can damage the vehicle, but I'm having a hard time seeing as to how that is possible. Would K&N oil work as well or are they different formulations and work differently?
motor oil works ok but not nearly as well as foam filter oil
foam filter oil has a carrier that evaps and leaves really sticky oil
regular motor oil tends to settle out at the bottom
use some motor oil wring out all the excess in paper towul you will be fine just redo it every few months
Oh perfect. Easy enough. Thanks , sir :)
HerrDeacon said:
Don't wring out the foam, just squeeze it. Wringing it will damage the foam.
Cool. I have a metal spiral inside that allows it to keep it's shape so the only thing I can to without damaging that is compress it along the length of the cylinder.
you can semi gently wring it out without damage,common sense used of course
a handy less messy way to do the saturation operation is inside a plastic bag
when the foam is easily damaged it is becoming rotten in my decades of experience
Hmm, I never new that about using motor oil instead of filter oil. I just installed some UNI filters and, lucky for me, my roommate had a life time supply of K&N filter oil. (any time I buy points lube, copper gasket sealer, hondabond, etc. it's like a life time supply because, I don't plan on using it too often lol)
xb33bsa said:
all we ever used back in the day racing was motor or 2 stroke oil
but we cleaned our filters ever race
when I was a kid every Saturday it was my job to clean the filters on my dad's lawn mowers and we would clean with gas and then dunk them in oil and squeeze the oil out and we didn't use gloves back then :)
mx, enduros,scrambles, observed trials,hare scrambles/cross country GP's, all knobby tire stuff
i never did the flat track roundy rounds wish i had tho
Cool! You hang on to your old race bikes?
For all you Loctite experts, how long does 518 take to cure or whatnot? It's not listed on the package or directions. I was thinking of installing the gasket tonight with sealant, torquing to 60 in-lb and then leaving overnight, then re torquing tomorrow.
Thoughts?
i have always tried to go 24hrs
for your own curious do a test piece or 2 at the same time
a coupl pieces metal and set a heavy weight onnit,with a small bead of 518 to squish, then do a destructive test after 12hrs,inspect do the other after 18hrs you get the idear
the stuff is amazing it is anairobik ;)
Cool I'll give it a shot. From what you're saying, I'm gathering it's going to be a PIA to ever get the gasket off the surface if I need to.
And come to think of it, I shouldn't have to re-torque if I'm using it as a thread locker on the bolts, lest I break the bond when I re-torque...?
