performance upgrades
primo
my understanding is that the uni longish sock slip on filters are a good performance upgrade for a cb350 twin than a pod filter since it uses the cross over tube for a better carb balance.
i'm also looking into a upgrade in muffler such as mac 2 to 1 for the best performance but the cost is hefty for me. what good option do i have if i want to keep my header pipes but replace the mufflers for an upgrade? i may just bite the bullet and get the mac. help a brother out
JP
screw the unis and stock air box...
go with some k & N filters on the stock carbs... youll have to go up two jet sizes or so...
most of us run custom exhaust pieces... im assuming you dont weld much otherwise i would tell you to make one. Mac is fine and will give a nice little power boost, but most of the gain comes from losing the weight of the stock headers.
while you have the carbs out go ahead and rebuild and clean them up. Youll get crisper throttle response with cleaner carbs.
if you want to take it to the next step go with a good set of coils and new plugs and wires. Electronic ignition is a wise investment and probably the most youll get for your money without cracking open the engine.
you can expect a couple of horsepower gain (around 5ish) with the mods listed above.
working on these bikes are easy. get yourself a clymer manual and download the shop manual
I've heard a hundred times on forums that anything but the stock airbox on a CB350s CV carbs is not an upgrade in performance. A pair of Mikuni carbs would probably be the way to go.
On the exhaust I guess it depends on wether you are wanting to open it up or keep back pressure. If I was opening it up I would buy some of those cheap shorty muffers, if not I would just stay stock if I was on a budget.
brianokc said:
Or do what Rocan said! we must have hit send at the same time.
haha within ten seconds of each other!
the stock cv carbs are used in vintage racing... they are good carbs, when they are set up right. Mikunis are just a bit more reliable.
also use the search function; been asked a million times.
