Petcock Help CB400
GodJockey
Hi everyone I am having problems finding a petcock to work with my tank/bike combo.
The tank is off a 78' or 79' CB400a and my bike is an 82' XS400 DOHC (the carbs require two lines).
the stock petcock from the CB400a's outlet goes towards the rear of the bike, but that won't work because it was just too much of a bend to go backwards to a T, so I need an outlet that goes strait down or even to the front of the bike. (the stock petcock is trashed too BTW)
I bought a "universial" pet cock from partsnmore.com figuring I'd be able to find two nuts from a hardware store for each thread and solder them together to make an adapter, but I can't find the correct thread nuts anywhere. I don't even know the correct thread patterns but they are both pretty big, and the testing chart at homedepot didn't work on them.
I need some peoples input on my options.
Thanks in advance,
Tom
If you look through the last couple pages of my build thread (link below) Jay Kent posted a link to an ebay seller that had all kinds of petcocks. The seller also listed all the measurements for them as well
I feel your pain brotha....
But it has each model with pictures and the measurements include center to center spacing, overall length, etc.. Do you think you would be able to use a fuel line splitter? Or would the carbs actually REQUIRE separate lines?
I tried to type that last post out real quick since you were online. Win some, lose some I guess.
I don't know if my bike requires a two outlet petcock, the one line has a CRAZY vaccuum. So I don't know if i need a diphram type petcock?
This is getting annoying looks all over the place.
Pretty sure that's a 16mm or 18mm thread?
I haven't tried a CB360 tap but it may fit and have dual outlets?
(I've got both CM400 tank and 360 tap but can't be bothered to go find them)
